m1735 engine bog using shredder
/ m1735 engine bog using shredder #21
Not a "shredder" it's a "rotary cutter"... Most often used vernacular is a "brush hog".... Cutter is probable to big for tractor (your tractor is rated at 36-40 HP) or you are trying to cut to much, to fast..... Cutter is actually recommended for tractors with 50 -150HP...
Yes,that cutter is too much for that tractor. But I believe that a 6 footer is required to clear the tracks on that tractor. I actually was considering a MF 1840M when I bought my tractor. It's got the same footprint as the 1735. I decided against it due to that reason.
Richardton 960 (A60462)
Richardton 960...
26120 (A56859)
26120 (A56859)
2016 FORD F-350 XL SUPER DUTY EXT CAB TRUCK (A59823)
2016 FORD F-350 XL...
UNUSED FUTURE FT-CL100C HYD CLAMP GRABBER (A52706)
UNUSED FUTURE...
2016 Homemade 7'X20' Trailer w/Ramps (A60462)
2016 Homemade...
2007 Heil Heavy Duty Aluminum Tank Trailer (A61307)
2007 Heil Heavy...
