lukinjohn
   / lukinjohn #1
lukinjohn
mt
craftman
Hi I have a 24 hp B & S,with Nikki carb,what would happen if you took the gas shut off solenoid off and put a plug were it was,thanks for the information,lukinjohn
   / lukinjohn #2
The engine will likely "diesel" after the key is turned off .
   / lukinjohn
Hi Mostly Gas,,thanks for reply,I was just wondering,thats the first one I seen ,thanks again lukinjohn
   / lukinjohn #4
It will backfire when you shut it down for one thing, the way it is now it has to open to allow fuel in also.
   / lukinjohn
Hi TOPPOP52 THANKS FOR THE REPLY,LUKINJOHN
   / lukinjohn #6
No problem, if you eliminate the valve, which I wouldn't, you will need to provide a way to cut the fuel off when you shut down the engine.
   / lukinjohn
Hi Toppop52,,will order new one,must stick,once and awhile have checked it if I put 12volts to it it works most of the time but sometimes it doesn't open ,running now,thanks for the help Louie
   / lukinjohn
Hi TOPPOP52 I will let you know what happens thanks again for the help Louie
2019 PETERBILT 579 TANDEM AXLE SLEEPER (A54313)
2019 PETERBILT 579...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A51222)
2006 CHEVROLET...
