Lucas CAV perkins 4.236 fuel pressure spring
   / Lucas CAV perkins 4.236 fuel pressure spring #1
Ivor2
Carraro 68.4
Hello
I've just bought some parts for the fuel pump on my perkins 4.236 , and they mixed up the springs , so i got two little transfer pressure regulating spring that's 6mm in diameter instead of a 10.6mm in diameter ;Lucas CAV DPA, DPS and DP200 transfer pressure spring - Diesel Injection Pumps and the delivery is expensive so i was wondering if anyone here knew the other specs of this spring , so i might be able to find it else where like amazon or a spring place or something .
Thanks
T
   / Lucas CAV perkins 4.236 fuel pressure spring #2
R u located in the STATES.??
You’re saying u need the big spring that holds down the pressure regulator.?
no in france . yes i need that spring
   / Lucas CAV perkins 4.236 fuel pressure spring #4
To bad, I would have gladly sent u one..
what's the size of it ? is there similar ones on amazon that'll work ?
Thank you , that's very nice
   / Lucas CAV perkins 4.236 fuel pressure spring #6
7135-33E sleeve retaining spring.
Thank you . is the diameter 10.6mm
   / Lucas CAV perkins 4.236 fuel pressure spring #9
Just measured the o.d. of the regulator plug.. the od of the long end..
Dual Cylinder Grapple Skid Steer Attachment (A51691)
Dual Cylinder...
(1) VISSANI REFRIGERATOR (1) FRIGIDAIRE REFRIGERAT (A51248)
(1) VISSANI...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2007 Ford Taurus SE Sedan (A51694)
2007 Ford Taurus...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
