Lucas CAV perkins 4.236 fuel pressure spring
   / Lucas CAV perkins 4.236 fuel pressure spring #1
Ivor2
Carraro 68.4
Hello
I've just bought some parts for the fuel pump on my perkins 4.236 , and they mixed up the springs , so i got two little transfer pressure regulating spring that's 6mm in diameter instead of a 10.6mm in diameter ;Lucas CAV DPA, DPS and DP200 transfer pressure spring - Diesel Injection Pumps and the delivery is expensive so i was wondering if anyone here knew the other specs of this spring , so i might be able to find it else where like amazon or a spring place or something .
Thanks
T
   / Lucas CAV perkins 4.236 fuel pressure spring #2
R u located in the STATES.??
You’re saying u need the big spring that holds down the pressure regulator.?
no in france . yes i need that spring
   / Lucas CAV perkins 4.236 fuel pressure spring #4
To bad, I would have gladly sent u one..
what's the size of it ? is there similar ones on amazon that'll work ?
Thank you , that's very nice
   / Lucas CAV perkins 4.236 fuel pressure spring #6
7135-33E sleeve retaining spring.
Thank you . is the diameter 10.6mm
   / Lucas CAV perkins 4.236 fuel pressure spring #9
Just measured the o.d. of the regulator plug.. the od of the long end..
2008 CATERPILLAR 12M MOTOR GRADER (A51406)
2008 CATERPILLAR...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2021 VemaTEC 30in Excavator Bucket (A51691)
2021 VemaTEC 30in...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
