Lucas CAV perkins 4.236 fuel pressure spring
   / Lucas CAV perkins 4.236 fuel pressure spring #1
Ivor2
Carraro 68.4
Hello
I've just bought some parts for the fuel pump on my perkins 4.236 , and they mixed up the springs , so i got two little transfer pressure regulating spring that's 6mm in diameter instead of a 10.6mm in diameter ;Lucas CAV DPA, DPS and DP200 transfer pressure spring - Diesel Injection Pumps and the delivery is expensive so i was wondering if anyone here knew the other specs of this spring , so i might be able to find it else where like amazon or a spring place or something .
Thanks
T
   / Lucas CAV perkins 4.236 fuel pressure spring #2
R u located in the STATES.??
You’re saying u need the big spring that holds down the pressure regulator.?
no in france . yes i need that spring
   / Lucas CAV perkins 4.236 fuel pressure spring #4
To bad, I would have gladly sent u one..
what's the size of it ? is there similar ones on amazon that'll work ?
Thank you , that's very nice
   / Lucas CAV perkins 4.236 fuel pressure spring #6
7135-33E sleeve retaining spring.
Thank you . is the diameter 10.6mm
   / Lucas CAV perkins 4.236 fuel pressure spring #9
Just measured the o.d. of the regulator plug.. the od of the long end..
   / Lucas CAV perkins 4.236 fuel pressure spring #11
It looks to big.??
And the p# I gave you, the 33E is the spring that goes INSIDE the sleeve..
2006 Chevrolet Silverado 2500 Knapheide Service Truck (A59230)
2006 Chevrolet...
2003 FORD F150 HARLEY DAVIDSON TRUCK (A59575)
2003 FORD F150...
2015 Ford F-350 4x4 Service Truck (A59230)
2015 Ford F-350...
KUBOTA ZG23F ZERO TURN LAWN MOWER (A60430)
KUBOTA ZG23F ZERO...
John Deere S350 (A60462)
John Deere S350...
2014 VOLVO A40G WATER TRUCK (A60429)
2014 VOLVO A40G...
