lubrication for 4WD.
/ lubrication for 4WD. #1
razorback98
Rogers , Ar
yanmar 1510d
I checked the lube in my 4WD(1510D) after running it for a while and it overflowed when I checked it. I was surprised to seeing it coming out. Is this because it was warm? I had checked it before when it was cold and didn't have a problem then. Thanks /forums/images/graemlins/confused.gif
/ lubrication for 4WD. #2
There should be a vent on the FWD differential or axle. Often bees or mud-dobbers find it to be an excellent place to call home. You should be able to poke it clear with a piece of wire and allow the axle to vent any pressure build up from temperatures generated by rotating gears and weather.
Hope that helps.
Mark
/ lubrication for 4WD. #3
If you find the vent, let me know. I've looked for one on my YM186D and can't find it.
2020 CATERPILLAR 279D3 SKID STEER (A65053)
2020 CATERPILLAR...
213135 (A64276)
213135 (A64276)
2016 FREIGHTLINER CASCADIA  125 6X4 T/A  DAY CAB TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
2007 50FT T/A 3 CAR HAULER TRAILER (A59914)
2007 50FT T/A 3...
2019 Ford F250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F250 4x4...
