Lubing FEL
/ Lubing FEL #21
<font color=blue>...rubber caps...were filthy...Did anyone on the forum have any trick solution for this...?</font color=blue>
I am not sure if you are keeping the caps snapped on to each other when the FEL is attached. I just keep the male & female caps connected. When I remove the loader, the outside may have dust on it, but the insides are clean and (still) oily from the last time they were detached.
/ Lubing FEL #22
<font color=blue>I am going to squirt some penetrating oil (WD-40 or equil) on the various connections, not grease</font color=blue>
I would advise against WD-40, as it will dissolve grease and oils. It also evaporates pretty quickly, leaving a dry slippery residue, which is great for closet door hinges, but not what is called for in industrial equipment lubrication. Your best bet is to use grease of some kind, even if its not moly. I agree with the moly being pretty messy, so I have switched to multi-purpose lithium. I believe the first 30 hours of use (before I stopped using moly grease) worked the moly into the metal surfaces pretty good.
/ Lubing FEL #23
No, I'm not. That never even occured to me......Thanks!/w3tcompact/icons/smile.gif
Jeff
2007 PETERBILT 379 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2007 PETERBILT 379...
2006 Ford F-250 4x4 Crew Cab Pickup Truck (A61573)
2006 Ford F-250...
CASE TV370 SKID STEER (A62129)
CASE TV370 SKID...
2014 FVCG TRAILER (A61567)
2014 FVCG TRAILER...
JOHN DEERE 7420 TRACTOR (A63291)
JOHN DEERE 7420...
Kubota Snow plow with subframe
Kubota Snow plow...
