LT2042 issues
   / LT2042 issues #1
ssallday
Brodheadsville, PA
05 CC 2042
My tractor hasn't been the best this year. Here are the problems I've noticed:
- Takes a while to start up even with the choke on.
- Takes around 5-6 seconds to start up after 2 hours of mowing
- When the PTO is engaged, the blades take a bit to get up to full speed
- The deck shakes a lot and does not operate smoothly while the blades are spinning. My mower went through 2 oem belts last year so I bought a stronger one off ebay. Not sure if this tighter belt is contributing to the issue
- The blades don't sound like they are spinning at full speed when the mower is at full throttle. The motor seems like it lacks power
I've never had any issues like this until the last couple of years. I'm not sure if they are fuel related or have something to do with the deck spindles, etc. The mower has around 260 hours.
   / LT2042 issues #2
"EVERYTIME" my deck starts shaking its BENT blades..
New blades takes care of the problem EVERY TIME.
I "upgraded" my blades from the MTD, find'm anywhere blades, to the industrial "gator blades"..{yellow}
They weigh about 5-10lbs MORE than the old blades & makes it hard to get up to speed..
The quality of the cut makes me "live with it".. I used to have to change my blades at least once a cutting season, {LOTS of sand}
I'm working on season #2 w/ no signs of wearing out..
The slow deck speed is probably belts..Or it needs a GOOD cleanin & greasin'..??
Do yourself a BIG favor & LOOK IN THE BOOK for the original belt #.. & BUY "IT"..
Ever since I did THAT.. its saved me a hundred $ every season from broken, stretched or thrown belts.. at 45.00 a wack, it doesn't take long to get into the hundred $ neighborhood..
   / LT2042 issues #3
- Takes a while to start up even with the choke on. Is the choke closing all the way
- Takes around 5-6 seconds to start up after 2 hours of mowing Could be related to the first question, but could also indicate a fuel problem, or possibly a vapor lock issue if the carb is getting hot.
- When the PTO is engaged, the blades take a bit to get up to full speed Is the deck belt tight and doesn't have burn marks or other issues, could also be related to your last question, Remove the belt and release the spindle brakes if your deck has them and make sure the blades turn freely.
- The deck shakes a lot and does not operate smoothly while the blades are spinning. My mower went through 2 oem belts last year so I bought a stronger one off ebay. Not sure if this tighter belt is contributing to the issue Bent blade or bad spindle bearing could create both of these issues.
See the bold text with your quote.
   / LT2042 issues
I had two oem belts and they both broke after a few uses. The belt I bought off ebay is much tighter and has worked very well. I bought new blades last season so I don't think it would would be blades, but I could be wrong
   / LT2042 issues
- The choke is closing all the way. Sometimes it doesn't start with the choke.
- Not sure if this would be the carb, but I've noticed the exhaust fumes are a lot stronger
- The deck belt is very tight and does not have burn marks. I have not replaced the other belt that sits on top of the deck (about 13 years old) but don't want to replace if it doesn't need it
- I'm thinking it could be a bearing now that you have mentioned it. Is there a way to check that? I'll have to post a video later of all the problems
   / LT2042 issues #6
Remove the deck entirely from the mower. Instructions are in the owner's manual. Owner's manuals are a free download at CubCadet.com.
Once the deck is out, I predict that your problems will be very obvious.
A too-tight deck belt is not good - causes excessive drag and wear. You can get a replacement for the OEM from these guys in Kevlar that will far outlast OEM - V-Belt Global Supply, LLC. | V-Belt Online Catalog
   / LT2042 issues #7
Belt breaking after a few uses indicates that something is going wrong. Either not installed correctly, wrong angle/cut of belt not fitting pulleys correctly, rubbing something that is damaging the belt, or just being abused. I would be looking into the spindle bearings and any idler pulleys, as well as checking the condition of any belt guides that could be damaged.
   / LT2042 issues #9
Small idler pulley sounds noisy, and would make a whining noise when running. The right spindle sounds like it could be dragging or a little rough also.
   / LT2042 issues
I may just replace the idler pulley. The right pulley doesn't spin as freely as the one on the left. Would that be a bad bearing or does it need a little grease? There's a little noise coming from it but it's not that loud
2019 BOBCAT T770 SKID STEER (A52709)
2019 BOBCAT T770...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2014 Sun Coastal 16' Cargo Trailer (A57148)
2014 Sun Coastal...
New/Unused 20ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 20ft...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A56438)
2018 John Deere...
24in Bucket Mini Excavator Attachment (A56857)
24in Bucket Mini...
