LT2042 issues
   / LT2042 issues #11
I may just replace the idler pulley. The right pulley doesn't spin as freely as the one on the left. Would that be a bad bearing or does it need a little grease? There's a little noise coming from it but it's not that loud
The bearings sound flat spotted, which can create a vibration when running. Had a brand new rider a few years ago that I had to replace all three spindles on because when running the vibration would make your feed go numb.
   / LT2042 issues #12
Remove the deck entirely from the mower. Instructions are in the owner's manual. Owner's manuals are a free download at CubCadet.com.
Once the deck is out, I predict that your problems will be very obvious.
A too-tight deck belt is not good - causes excessive drag and wear. You can get a replacement for the OEM from these guys in Kevlar that will far outlast OEM - V-Belt Global Supply, LLC. | V-Belt Online Catalog
The prices offered in your link seem high. A BP158 for $45.
I have been buying Carlisle, Gates and another brand I cannot remember, BP belts for less than 1/2 that price.
Am I missing something. The "P" is the generic designator for Kevlar so I am comparing apples with apples.
Dave M7040
   / LT2042 issues
I think I will replace the bearings in the spindle. Where can I get them cheap?
   / LT2042 issues #14
When you take it off/out it will have #'s stamped on the brg. housing.. just search those #'s..
GET SEALED BRG'S.!!!!
Theres a BIG diff. in "CHEAP" & "less expensive".. cuz theres ALOT of "CHEAP" brgs on the market..
Your probably making a big mistake by not doing all of them at once.. How many times do you want to take the deck off??
& if that "1" brg doesn't fix the problem, your gonna start 2nd guessing yourself..
You ALREADY SAID, 1 doesn't spin as smoothly as the other..
Do it ALL at once.. brgs, belts & blades.!!!
   / LT2042 issues
It is annoying taking that deck off. Correct me if I'm wrong, but does each spindle have 4 bearings? According to the diagram, there's a cup and cone bearing. Would I have to replace all 4 or just the cup bearing?
It's on page 42 in the manual: Cub Cadet LT242 Parts Diagrams
   / LT2042 issues #16
item 22 and 23 make up one bearing. the are a tapered roller bearing like a wheel bearing on a car. So each spindle requires 2 each of item 13 which is the seal, item 22 the taper bearing, and item 23 the bearing race as it is called. And the bottom seal is installed backward meaning that the open side faces out so the extra grease can be pushed out without pushing out the top or bottom seal.
   / LT2042 issues
Took the bearing out today. I can see that it's one piece like you said. I was surprised with the amount of grease inside the housing.
   / LT2042 issues
Update: Finally found some time to replace all 4 bearings and the idler pulley. Everything runs smoother but the one blade still doesn't spin as freely as the other. The motor also has a decent bog when the pto is engaged
   / LT2042 issues #19
Perhaps the belt is dragging against the pulley.
Well there you go. I don't like the electric clutches. Most of the time, you have to have the engine running at nearly full throttle when you engage the clutch. That's one helluva slam on the engine, belt, and deck bearings.
One would think that the engineers at the company could come up with an electric clutch that engages smoothly. Perhaps progressive increase of current thru the clutch coil.
Richard
   / LT2042 issues
Richard
From what I remember, I don't think the pto ever bogged as much as this. People with who had similar issues were saying that the motor could be operating on one cylinder instead of two
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
2872 (A58376)
2872 (A58376)
2005 EAST 45' WALKING FLOOR TRAILER (A54756)
2005 EAST 45'...
2014 WESTERN STAR 4900 SB ROAD TRACTOR (A51406)
2014 WESTERN STAR...
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
Skid Steer 66in Skeleton Bucket (New/Unused) (A59225)
Skid Steer 66in...
