lt1042 electrical problem
/ lt1042 electrical problem #1
czechfarm
I keep popping 20 amp fuses when I go in reverse. Recently dropped and reinstalled the deck - mowed for about 30 mintues - then it popped. Put in a new one and the same thing happened. Would appreciate any ideas.
/ lt1042 electrical problem #2
The new 2K series has this problem due to burnt/scortched insulation on the headlamp wiring causing a short. I'd check that and check over the PTO wiring for a cut, burn mark, etc..
G/luck
Joel
Oxy-acetylene Torch and Regulator Rig (A63689)
Oxy-acetylene...
2005 John Deere 7420 (A60462)
2005 John Deere...
(2) Denman Tires w/Rims (A64127)
(2) Denman Tires...
1990 Ford 3930 Tractor (A65579)
1990 Ford 3930...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 FREIGHTLINER...
MARKER LIGHTS (A64276)
