LSTractor Control Valve Problem
/ LSTractor Control Valve Problem #1
BrittCook
Kenai, Alaska
LS/XR3037HC
LSTractor XR3032HC
Having problems with my G827S0102 Remote control valve. Tractor is almost new & Detent Control is very difficult to get in and out of detent. Tractor is under warranty by I am quite a distance from my distributor. Anyone with similar problem or solution?
/ LSTractor Control Valve Problem #2
Welcome to TBN................
If this just started happening there may be an internal problem with the valve that will require disassembly and repair.
If the tractor is new it will loosen up with use.
/ LSTractor Control Valve Problem #3
G'day Mate and welcome to TBN from Downunder.
Not knowing how experienced you are; have you shut off the engine and released the hydraulic pressure before operating the detent control?
I hope I haven't miss-read your problem.
/ LSTractor Control Valve Problem #4
Welcome to the forum. :welcome:
Hopefully you'll find some answers between this thread and your one over in the LS section. :thumbsup:
Used the Valve all last summer with stump grinder. It was very difficult to get in & out of detent. Had to use 2 hands to keep from going too far when it engaged. Thought it was probably in the valve but thought I would check to see if anyone had experienced this. Thanks much for the info.
2008 DOOSAN G25 GENERATOR (A60736)
2008 DOOSAN G25...
2019 BOBCAT MT55 WALK BEHIND SKID STEER (A59823)
2019 BOBCAT MT55...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52707)
(INOP) 2016...
2020 CATERPILLAR 259D3 SKID STEER (A62129)
2020 CATERPILLAR...
FIFTH WHEEL ATTACHMENT PLATE (A60736)
FIFTH WHEEL...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
