LS backhoe factory thumb
/ LS backhoe factory thumb #21
mine did the same I thought my reflexes were screwed up lol
later i read that's common and some forum people not mechanically inclined ( prerequisite to tractor ownership imo ) were venting about how the lever was poorly designed hit the stabilizer control lol
I got really lucky with mine. I had not used the backhoe in a bit and I noticed it after I unmounted it . For some reason I reached up and jiggled the joystick and noticed it was extra wobbly. Had I reattached the hoe and drove around for a few hours I would have been picking up the pieces all around the yard. Bit of a sixth sense happening there I guess LOL.
/ LS backhoe factory thumb #22
Paid $250 for mine from dealer in CA. I like it...use it allot...no issues so far with the thumb.
/ LS backhoe factory thumb #23
Same thumb but my backhoe came with the mount point already welded on. I'm assuming a newer model, got mine early 2020. I haven't used it but 3 or 4 times, but in those times it was really nice to have. Would be really great if it had a hydraulic ram of it's own but I've not used it enough to justify that yet.
Hi there . That looks awesome. I have been searching for a bolt on thumb for the backhoe on my LS g3033h . The Titan bolt on would have done the trick I think but it seems to not be very available in Canada . Any time I saw it (rare) , it was hugely over priced.
If you don't mind my asking , how much does LS want for that thumb ?
What model backhoe do you have on your G3033H?
/ LS backhoe factory thumb #25
It's an LB1100 with subframe .
I have the same tractor and hoe as you. I want to install a bolt-on thumb. I measured the dipper arm and it's 3 3/8". Titan states theirs fits a 3.25". Have you actually installed their thumb on your hoe? I don't want to weld one on and not big on cutting theirs in half to widen it. Looking for a "perfect" fit.
/ LS backhoe factory thumb #26
No I am still in the shopping stage. I thought back when I was looking at titan that their thumb would require a 1/8th or 1/4 inch shim to make it work properly. Been a year or two since I looked at it though. Things may have changed or I simply may have misread.
/ LS backhoe factory thumb #27
I recently bought a MT468CPS with the LB3102 backhoe. As best I can tell, the hoe is exactly the same as the Kioti KB2485.
With that being said, I can't seem to find an actual listing for the factory thumb for either of these models. The dealer I bought the tractor from said he would call their rep and see about one. The DKA147 appears to be it, but havent found it on any parts websites, etc.
Like Kormidoit, this one already has the mount welded in place to accept one.
The salesman I seem saddled to seems like a nice enough fella, but doesn't know much about LS. I think I knew more about the tractor than he did. He didn't think LS offered a thumb.
LS is one of 3 or 4 brands they carry at this large dealership, 125 miles north. Yes, I am a little concerned that it is so far away.. It was the closest place I could find something that met my criteria that wasn't going to take until mid-Summer to be delivered. And the reviews were positive.
They had an older XU6000 series in the shop split open. The mechanic walked me around it and showed me everything that would be hard to see on the assembled MT. He also showed me the results of the owner not servicing it nor keeping hydraulic fluid in it.. One of the other fellas spent about an hour with me in the back lot coaching me through the functionality of everything. Last tractor I used was the old Ford when I was kid. All in all a good experience. They weren't giving out discounts or free stuff to get folks to buy what inventory they had.. I "think" I saved a little by packaging it all into one purchase. Buy once, cry once..I hope!
I don't know if I will ever need 3 cruise control settings.. As long as it outlives me, I will consider it a good purchase. I am sure everyone starts out believing they will never need to buy another/bigger tractor..
/ LS backhoe factory thumb #28
Found and bought DKA147 from a Kioti dealer about 90min away. Got home and started install only to find it had the smaller bucket pin in the kit (for the CKA kit). Box was in poor shape, but was labeled DKA147. The dealer is going to call Kioti on Tuesday to get correct pin. They checked the other kit they had on hand as well as a couple of thumbs on hoes in their yard and all had the smaller pin. We will see.
The LS dealer (Legacy Tractor in Ft Collins) said they didn't know when they could get one and their rep didn't either.
Otherwise seems like a pretty straight forward install.
/ LS backhoe factory thumb #30
I failed to come back and close the loop here. The folks at The Hitchin' Post in Florissant, CO brought the correct pin down to Col Springs for me. The re-install was pretty straight forward. The DKA147 is correct fit for the LB3102 hoe.
/ LS backhoe factory thumb #31
I'm looking for a thumb for my LB2100 backhoe. Can someone point me in the right direction?
/ LS backhoe factory thumb #32
thats the backhoe model I have and after seeing this thread if I can't find a part from Kioti I will look at the LS lol
if you need any kioti thhumb measurements feel free to ask
Hi Zmann. Older thread but I am thinking you will see this. I hooked up my backhoe about a month ago and quickly noticed that there was a lot more movement in the whole backhoe when I was digging . I stopped to investigate and low and behold the 4 main bolts holding the hoe onto the subframe had loosened up. I retightened them and all seems well now. If you look at the picture of my backhoe you will see the 2 big bolts on either side just under the step by the stabilizer . I am getting my 300 hour service done in a week or so and asked the guy if he had heard of this and he said that hoe was known to do that and just keep an eye on it and retighten as needed. Locktight next time I think.
Anyway , just something to check on your hoe once in a while.
Cheers.
/ LS backhoe factory thumb #33
I have had the same issue on mine. I check them every so often and tighten as needed. They're pretty large, so it is difficult to overtighten them.
2017 Ford Expedition SUV (A61574)
2017 Ford...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
Rotary SPOA9-200 Automotive Lift (A59228)
Rotary SPOA9-200...
2017 MACK CXU613 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2017 MACK CXU613...
Titan Attachments Forks (A64126)
Titan Attachments...
2006 Ford Crown Victoria Sedan (A61574)
2006 Ford Crown...
