LS backhoe factory thumb
/ LS backhoe factory thumb #1
seasnake
sacramento , Ca
LS XR4140h
Hi All I bought the factory thumb for my backhoe tractor is an XR4140H , I havent used it yet but it seems to be very strong . it only came with two pages of drawings no instructions so it took about an hour to get installed . Also you might notice my tractor is in a 20' shipping container yes it fits with the bucket curled down and the backhoe slightly tilted right or left and the doors will close just fine.
/ LS backhoe factory thumb #2
Hi there . That looks awesome. I have been searching for a bolt on thumb for the backhoe on my LS g3033h . The Titan bolt on would have done the trick I think but it seems to not be very available in Canada . Any time I saw it (rare) , it was hugely over priced.
If you don't mind my asking , how much does LS want for that thumb ?
/ LS backhoe factory thumb #3
same unit supplied for my kioti
I think the price was cheap it is actually two kits the thumb and the bolt on thumb mount it was like 340 for both
some later kioti's have a thumb bracket so they did not need the bolt on bracket
i found online videos and pdf for the kits so if LS is not showing up in searches maybe try kioti ?
/ LS backhoe factory thumb #4
related
/ LS backhoe factory thumb #5
the thumb kit is strong, I use it to pick up boulders all the time
/ LS backhoe factory thumb #6
Thanks for that. I noticed early on that my backhoe and one size of the kioti backhoes looked like the same manufacturer . The KB2465 seems to be a match for my unit. I will look into the pricing and availability up here . I was always hesitant because of a possible mistake . Pretty pricey if it does not fit right but it seems I was right about it being the same unit.
BTW Seasnake , didn't mean to hijack your thread !
/ LS backhoe factory thumb #7
thats the backhoe model I have and after seeing this thread if I can't find a part from Kioti I will look at the LS lol
if you need any kioti thhumb measurements feel free to ask
/ LS backhoe factory thumb #8
Same thumb but my backhoe came with the mount point already welded on. I'm assuming a newer model, got mine early 2020. I haven't used it but 3 or 4 times, but in those times it was really nice to have. Would be really great if it had a hydraulic ram of it's own but I've not used it enough to justify that yet.
/ LS backhoe factory thumb #9
I would have just welded that thumb bracket on mine but did not want any trade in issues
and Kioti priced the thumb bracket super cheap IMO at 65 bucks
wonder who makes this backhoe for LS and Kioti ,, it is a good unit ,, I know the Kioti has two versions of the operator lever valves
mine uses the one without top panel boots on the boom controls
/ LS backhoe factory thumb #10
I thought I had read somewhere a long time ago that it was Ansung . Not sure about that by any means though. lol
/ LS backhoe factory thumb #11
good call I could see Ansung making the OEM variant for LS and Kioti
looks pretty familiar in many places
/ LS backhoe factory thumb #13
i have mine off so I will take a pic so we can compare
/ LS backhoe factory thumb #14
Yours looks great!
I have been waiting 3 and a half months for my dealer to get a thumb for my MT225 LB1300 backhoe. I called some LS dealers first up to 150 miles away to see if any one had it in stock. No luck.
I got from the dealer they first wanted 400+ but i asked them for a deal and they came back with $380
/ LS backhoe factory thumb #16
That seems to be a very reasonable price to me. It will be more up here in Canada but still still probably not bad. Thanks for the info. Gonna look into this . (y)
/ LS backhoe factory thumb #17
I see some differences like the sub frame angle on the LS where mine is a stair step, but obviously it is the same hoe
/ LS backhoe factory thumb #18
here are the kioti part #s if interested
  • CKA165-DKA147-THUMB-KIT-06-2019 (1).pdf
/ LS backhoe factory thumb #19
Exact same implement . I did have one of the levers loosen up this summer . Just something to check once in a while just like every other bolt on a tractor.
Thanks for the parts info .
/ LS backhoe factory thumb #20
mine did the same I thought my reflexes were screwed up lol
later i read that's common and some forum people not mechanically inclined ( prerequisite to tractor ownership imo ) were venting about how the lever was poorly designed hit the stabilizer control lol
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2015 JLG G12-55A TELEHANDLER (A67714)
2015 JLG G12-55A...
2016 John Deere 3039R 38HP 4WD Utility Loader Tractor (A66734)
2016 John Deere...
DRIVE WHEEL W/ PUMP (A65054)
DRIVE WHEEL W/...
2022 CHEVROLET TAHOE (A66091)
2022 CHEVROLET...
2014 Ford E-350 Cargo Van (A66736)
2014 Ford E-350...
