LPGS For Kubota B2910
   / LPGS For Kubota B2910 #91
Throw the FEL and bucket (797 lb) on and that 1740 lb tractor instantly becomes a 2600 lb tractor.
Add an 800 lb implement on the rear and it's now a 3400 lb tractor.
I will have the ability to vary my "bite" instantly tho' ... with a simple push of a lever ... ;)
What is the skid length on your 8' wide unit ?
There's little doubt (in my mind anyways) that longer is better ... since length coincides with the direction of travel.
But there is also an issue - at least for me and my equipment - of weight past the pins on the 3PH ...
You can add the weight of the fel so with a bucket of dirt you would have about 3,000 lbs. If you have filled tires or wheel weights that would help too. When you drop the lpgs on the ground you can't add that as weight for traction purposes.
While you can raise the cutting edge to regain traction it isn't doing you much good at that point. I am still interested in your design though and hope it works out.
Both of my lpgs have 60" skids oal. Sorry I was mistaken and thought I had included that previously.
Weight is an issue for everyone but I don't see that being the problem for your 3ph at this point. The hitch can easily lift more implement than you can pull.
Consider this for a moment, when a 6' wide land plane is engaged with the ground it has two blades for a total of 12' of blade for drag.
I worked with my 8' lpgs all day and there were times that it was a hard pull. I am just trying to help with advice based on my experiences. Good luck with this and hope it turns great for you.
Sure do wish I could operate a computer to make pretty drawings like that.
All it takes is time and persistence ... and a high tolerance for software bugs, bad interfaces, and poorly designed (or non-existant) tools ... :laughing:
Got "sketchUp" downloaded, but too dumb to do anything with it:laughing:
I downloaded it most recently back in 2012 (SketchUp 8) ... of course, I never found any time to spend to sit down and learn it ... :rolleyes:
But I'm downloading the current version right now ... 'cause I really need some more hard drive clutter ...:laughing:
   / LPGS For Kubota B2910 #93
My view on Sketchup when you first fire it up seems useless. BUT go watch and run thru the tutorial videos on how to use it which doesn't take long and suddenly it makes total sense and wow is it ever a great program!!! That's my thoughts on Sketchup. Take the time to learn it and you'll be happy you did.
E.
Scott (?) ... stop makin' so much sense will ya ?
... :laughing:
Unfortunately I don't have wheel weights or filled rears ... the B2910 doubles as our primary lawnmower and I wanted to keep a light footprint, figuring that I could add ballast as the particular tasks demanded it.
This is one instance where that logic has failed me.
I do too ...
If I had a little more common sense - as well as patience - I probably would have held off for a bit and considered the dimensions a little more carefully before I started slicin' and dicin' ...
My primary consideration at the time was utilization of the materials I had (two 7' long pieces of 10" c-channel) and avoiding waste. Making the decision to go with 6' wide x 4' long (or 4' 6") allowed me to fully utilize the drops off the c-channel for the tailgate.
Truth is I had made the decision long ago to go with a 6' width ... and I had three drops (two 3" x 3" x 3/8" angles and one piece of 2" Schedule 80 pipe) from prior projects already cut to that length. Obviously it was a decision that wasn't all that well researched ... since I'm using none of those pieces in this build.
You may well have ... but I didn't go back and search this thread to find it while I was replying to your post.
These days my short-term memory is starting to suck a bit ...
Yup, probably true ...
My concrete ballast block (roughly 22" wide x 25" long x 29" tall)- which is awaiting modification to lighten it - weighs on the order of 1100 lbs and is mostly all behind the pins (especially considering the QH adds another 4" or so) ... and it will lift it ... barely ...
Always with the good points ... :laughing:
It will be interesting to see how it operates as a practical matter ... given the design principles and features I'm incorporating into it.
As an example, if I were working terrain that was lumpy and fairly uneven, I'd think that I would be initially able to set the blades high and carve off the high spots. That would avoid having all of that 12' of cutting edge engaged at once.
Of course, at some point, all of it will be engaged ...
Hmmm ... that just got me thinking ...
I originally designed it for the blades/cutting edge carriers to pivot off the rear carrier ... wonder what the practical implications of using the front carrier as the pivot point would be ... ?
Gonna have to ponder that a bit ... :scratchchin:
I know you are ... and it appears to me that you certainly do have some real-world experience, since from what I've read you appear to be doing this on a commercial basis.
So your comments about my tractor being able to pull it successfully are causing me some angst ...
But that's totally fine ... I'd rather have your candid input than not ... :thumbsup:
Thanks ... I certainly do appreciate the thought - and the time and effort - you have expended to offer your advice/input.
Nevermind ... I already see a practical problem with changing the pivot point: raising the one blade would cause the other blade to do the reverse, due to the cutting edges being located on the front sides ...
Doh !
   / LPGS For Kubota B2910 #97
Doh !
If you really want to pursue the hydraulic blade height it would be better to use four short pin joint levers as mounting points for the side mount carriers. This would allow you to raise and lower the blades keeping them level. Much like parallel bars on a fel. Some short pin joints with 4 to 6 inch pin to pin would be much stronger than what you have drawn. Set these mounting joints to be in tension not compression. I will try to sketch this up tonight for you.
   / LPGS For Kubota B2910 #98
Maybe leave the blades rigidly attached to the frame sides, and raise/lower the skids below the sides?
Bruce
Thanks, appreciate it.
I get the idea (of parallelism) ... but I'm not exactly following you on the actual mechanism.
Just got back from my steel suppliers from picking up the 2 1/2" square tube and the 2 1/2" x 3/8" flat. Fortunately I had enough presence of mind to grab 3' of 1" cold-roll solid while I was there for pins.
Maybe that would be suitable for what you're talking about ?
Anyways too nice outside to be inside so I'm going to see what kind of trouble I can get into outside ... :laughing:
Bruce
Defacto the frame sides are the skids ...
(Edit: It occurs you may have meant the 3PH frame ... ?)
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A55745)
2010 MAXEY WELDING...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
2022 Ram 2500 (A55973)
WATER TRAILER (A58214)
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
