LPGS For Kubota B2910
   / LPGS For Kubota B2910
BTW, I made mention of Kubota's maximum recommended implement weights on the 3PH, which I believe are probably fairly conservative.
Here's some additional data:
Maximum Lift Force @ pins: 1655 lbs
Maximum Lift Force 24" behind pins: 1300 lbs
That's the stock rating ... but my PRV is jacked up 200 psi over stock.
   / LPGS For Kubota B2910 #82
I'm no expert, but I just know that my 5' land plane is all my JD 2720 wants to handle when it gets a bit of rock in it. My driveway is on a hill and with the land plane less than half-full, it's spinning all four tires trying to go uphill. I normally go downhill for that reason, but I want to drag some of the rock that washed down back up the hill. My JD is about the size of your Kubota. The JD may be just a tad heavier, and I usually leave the loader on when using the land plane for a little extra weight.
Anyway, look forward to your build!
Worked out all the hydraulic cylinder attachment points and brackets.
The tailgate cylinder is Lion 2 1/2" bore x 10" stroke 2500 psi cylinder with SAE ports. Surplus Center must have an overstock of them (200+ in inventory) and be trying to move them because they were pretty cheap ($50)
It will provide slightly greater than a 90 degree range of motion, with the present bracket geometry and attachment points.
The blade adjustment cylinder is Wolverine (Prince) 2 1/2" bore x 4" stroke 2500 psi cylinder with SAE ports. A little pricier @ $64.
With the present bracket geometry and attachment points, it will provide a blade adjustment range of roughly minus 1 1/2" (cutting edge depth below the skids ... variable, depending on exactly where on the carrier I mount the cutting edge) to a positive height over 9" above the skids (again, varies on cutting edge mounting)
There is a potential interference issue with the top of the blade and my SpeeCo Quick Hitch ... but it's fairly slight. Might see if I can fix that.
If you haven't already, trying filling the bucket on the FEL ... it'll get ya a little more traction ... wet soil or gravel works good ... ;)
Have similar issues with our 3PH snowblower (no chains, R4's) ... always blow downhill ... :D
My JD is about the size of your Kubota. The JD may be just a tad heavier, ...
Yup, it is ... very similar machines tho' ...
... and I usually leave the loader on when using the land plane for a little extra weight.
:thumbsup:
Thanks ... enjoy !
A few new renders:
Blade down:
Blade up:
Non-perspective (flat) sideview with blade up. (You can see the potential inference issue):
A perspective three-quarter view:
(Might be more like 10:00 or 11:00 ... :laughing:)
   / LPGS For Kubota B2910 #88
Last time, I decided I was going to try that next time. ;) Thanks for the tip!
One more from towards the rear:
   / LPGS For Kubota B2910 #90
Sure do wish I could operate a computer to make pretty drawings like that. Got "sketchUp" downloaded, but too dumb to do anything with it:laughing:
CATERPILLAR HM315C QUICK ATTACH HYD MULCHING HEAD (A54757)
CATERPILLAR HM315C...
12' CONTAINER (A52706)
2005 International 5900i T/A Flammable Liquid Transport Truck (A55973)
2005 International...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
2021 ASV RT-120F FORESTRY SKID STEER (A52709)
2021 ASV RT-120F...
2019 VOLVO VNL64T860 TANDEM AXLE SLEEPER (A58018)
2019 VOLVO...
