LPGS For Kubota B2910
   / LPGS For Kubota B2910
BTW, I made mention of Kubota's maximum recommended implement weights on the 3PH, which I believe are probably fairly conservative.
Here's some additional data:
Maximum Lift Force @ pins: 1655 lbs
Maximum Lift Force 24" behind pins: 1300 lbs
That's the stock rating ... but my PRV is jacked up 200 psi over stock.
   / LPGS For Kubota B2910 #82
I'm no expert, but I just know that my 5' land plane is all my JD 2720 wants to handle when it gets a bit of rock in it. My driveway is on a hill and with the land plane less than half-full, it's spinning all four tires trying to go uphill. I normally go downhill for that reason, but I want to drag some of the rock that washed down back up the hill. My JD is about the size of your Kubota. The JD may be just a tad heavier, and I usually leave the loader on when using the land plane for a little extra weight.
Anyway, look forward to your build!
Worked out all the hydraulic cylinder attachment points and brackets.
The tailgate cylinder is Lion 2 1/2" bore x 10" stroke 2500 psi cylinder with SAE ports. Surplus Center must have an overstock of them (200+ in inventory) and be trying to move them because they were pretty cheap ($50)
It will provide slightly greater than a 90 degree range of motion, with the present bracket geometry and attachment points.
The blade adjustment cylinder is Wolverine (Prince) 2 1/2" bore x 4" stroke 2500 psi cylinder with SAE ports. A little pricier @ $64.
With the present bracket geometry and attachment points, it will provide a blade adjustment range of roughly minus 1 1/2" (cutting edge depth below the skids ... variable, depending on exactly where on the carrier I mount the cutting edge) to a positive height over 9" above the skids (again, varies on cutting edge mounting)
There is a potential interference issue with the top of the blade and my SpeeCo Quick Hitch ... but it's fairly slight. Might see if I can fix that.
If you haven't already, trying filling the bucket on the FEL ... it'll get ya a little more traction ... wet soil or gravel works good ... ;)
Have similar issues with our 3PH snowblower (no chains, R4's) ... always blow downhill ... :D
My JD is about the size of your Kubota. The JD may be just a tad heavier, ...
Yup, it is ... very similar machines tho' ...
... and I usually leave the loader on when using the land plane for a little extra weight.
:thumbsup:
Thanks ... enjoy !
A few new renders:
Blade down:
Blade up:
Non-perspective (flat) sideview with blade up. (You can see the potential inference issue):
A perspective three-quarter view:
(Might be more like 10:00 or 11:00 ... :laughing:)
   / LPGS For Kubota B2910 #88
Last time, I decided I was going to try that next time. ;) Thanks for the tip!
One more from towards the rear:
   / LPGS For Kubota B2910 #90
Sure do wish I could operate a computer to make pretty drawings like that. Got "sketchUp" downloaded, but too dumb to do anything with it:laughing:
2015 JOHN DEERE 35G EXCAVATOR (A52709)
2015 JOHN DEERE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2013 VOLVO NVL TANDEM AXLE SLEEPER TRUCK (A58017)
2013 VOLVO NVL...
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
PALLET OF MISC PARTS & SUPPLIES (A58374)
PALLET OF MISC...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
