Lower link pin
/ Lower link pin #1
filly862
B23 kaboda
Hi! My lower link pin keeps popping out of my 3 point hitch when running my brush hog. It’s a 13” steel rod that goes through the lower arms & has a flat triangle shaped piece that curves over the rod & bolted on. That holds the adjustable stabilizers. Do I need to adjust the sway/stabilizers?.. Kim.
/ Lower link pin #2
Kim
Can you post some pictures of what have and also provide make and or model of the tractor and bush hog.
/ Lower link pin #3
Kim - I'm a bit confused. A picture or two would sure help.
/ Lower link pin
/ Lower link pin
Pictures of my Kurosawa, & the lower link pin & stabilizers..
/ Lower link pin
The 2nd picture is of the flat plate that hooks onto (curves over) the lower link pin.. I figured out how to tighten the stabilizers today.
/ Lower link pin #7
Unless there is big difference from the BX22 there are plated bolted to the frame on each end of the pin to keep the 13" shaft from coming out.
2012 PETERBILT 386 (A65643)
2012 PETERBILT 386...
10in. Auger Bit (A65640)
10in. Auger Bit...
1996 Champion 540P (A64126)
1996 Champion 540P...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2022 Great Plains 3000TM Turbo Max VT (A66285)
2022 Great Plains...
2002 Massey Ferguson 1233 Tractor (A66285)
2002 Massey...
