Lower link pin
/ Lower link pin #1
filly862
B23 kaboda
Hi! My lower link pin keeps popping out of my 3 point hitch when running my brush hog. It’s a 13” steel rod that goes through the lower arms & has a flat triangle shaped piece that curves over the rod & bolted on. That holds the adjustable stabilizers. Do I need to adjust the sway/stabilizers?.. Kim.
/ Lower link pin #2
Kim
Can you post some pictures of what have and also provide make and or model of the tractor and bush hog.
/ Lower link pin #3
Kim - I'm a bit confused. A picture or two would sure help.
/ Lower link pin
/ Lower link pin
Pictures of my Kurosawa, & the lower link pin & stabilizers..
/ Lower link pin
The 2nd picture is of the flat plate that hooks onto (curves over) the lower link pin.. I figured out how to tighten the stabilizers today.
/ Lower link pin #7
Unless there is big difference from the BX22 there are plated bolted to the frame on each end of the pin to keep the 13" shaft from coming out.
