Lower link pin
/ Lower link pin #1
filly862
B23 kaboda
Hi! My lower link pin keeps popping out of my 3 point hitch when running my brush hog. It’s a 13” steel rod that goes through the lower arms & has a flat triangle shaped piece that curves over the rod & bolted on. That holds the adjustable stabilizers. Do I need to adjust the sway/stabilizers?.. Kim.
/ Lower link pin #2
Kim
Can you post some pictures of what have and also provide make and or model of the tractor and bush hog.
/ Lower link pin #3
Kim - I'm a bit confused. A picture or two would sure help.
/ Lower link pin
/ Lower link pin
Pictures of my Kurosawa, & the lower link pin & stabilizers..
/ Lower link pin
The 2nd picture is of the flat plate that hooks onto (curves over) the lower link pin.. I figured out how to tighten the stabilizers today.
/ Lower link pin #7
Unless there is big difference from the BX22 there are plated bolted to the frame on each end of the pin to keep the 13" shaft from coming out.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Towable Generator (A60352)
Towable Generator...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
John Deere 4240 w/ Loader and Hay Spear (A64047)
John Deere 4240 w/...
2000 CATERPILLAR 988F SERIES II WHEEL LOADER (A62129)
2000 CATERPILLAR...
2002 SHOP 20' FLATBED GOOSENECK (A63569)
2002 SHOP 20'...
