Mowing lower 3ph without mower going down?
/ lower 3ph without mower going down? #1
Anonymous Poster
Epic Contributor
I'm a new owner (with the bank) of a BX2200. Is it possible to lower the 3ph with a box blade without the mid-mount mower going down also?
thanks,
oj
I think I asked that backwards. Can you lower the mower with out lowering the 3ph?
thanks,
oj
/ lower 3ph without mower going down? #3
Raise the deck to its highest position then turn the cutting height control knob to "TOP". It will still go down -- but not much. If you need more ground clearance you can set the guage wheels to the lowest hole.
Huck
/ lower 3ph without mower going down? #4
No, Ozark John, you cannot. You could fix a chain to hold up the rear 3 point but on the BX they are operated together by the same lever. I usually remove the mower deck when using rear implements. Besides all that weight on my lawn area when mowing just compacts my soil worse than it is already. J
2007 30ft. Regal 30 Express Cruiser Boat with 2010 Vantage T/A 33 Ft. Trailer (A64557)
2007 30ft. Regal...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
MAN BASKET (A64553)
MAN BASKET (A64553)
Cowboy Statue (A64557)
2006 International 7600 T/A Flatbed Truck (A64194)
2006 International...
58in Wagon Wheel Bench (A65583)
58in Wagon Wheel...
