Mowing lower 3ph without mower going down?
/ lower 3ph without mower going down? #1
Anonymous Poster
Epic Contributor
I'm a new owner (with the bank) of a BX2200. Is it possible to lower the 3ph with a box blade without the mid-mount mower going down also?
thanks,
oj
I think I asked that backwards. Can you lower the mower with out lowering the 3ph?
thanks,
oj
/ lower 3ph without mower going down? #3
Raise the deck to its highest position then turn the cutting height control knob to "TOP". It will still go down -- but not much. If you need more ground clearance you can set the guage wheels to the lowest hole.
Huck
/ lower 3ph without mower going down? #4
No, Ozark John, you cannot. You could fix a chain to hold up the rear 3 point but on the BX they are operated together by the same lever. I usually remove the mower deck when using rear implements. Besides all that weight on my lawn area when mowing just compacts my soil worse than it is already. J
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2019 HYUNDAI V12530152-AJS 53' 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
2002 Mitsubishi Lancer Sedan (A64557)
2002 Mitsubishi...
2022 EZ-GO ELITE...
