Low oil pressure sensor + diesel generator
   / Low oil pressure sensor + diesel generator #1
dlabrie
Campton, NH
Kubota B2910
I have a 5 year old Aurora portable diesel generator, # AGI16500DE. It has an 11 HP, 186F type, single cylinder, 3600 rpm, diesel engine.
The oil pressure sensor is leaking. I tried tightening it but that didn't work. Can anyone tell me if this sensor is an off-the-shelf item? I found this Amazon.com: Standard Motor Products MC1804 Oil Pressure Gauge Switch: Automotive on Amazon, but have no idea if it would work.
Here is a picture of the leaking sensor.
Thanks.
   / Low oil pressure sensor + diesel generator #2
Have you tried removing it and putting teflon tape on it?
DEWFPO
DEWFPO
No, It's not leaking from the threads. It is coming from the seal between the black part and the ring.
The manual says it is a 15PSI sensor, but I can't find any info on PSI ratings on Amazon.
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
CUSTOM ALUMINUM 16FT CAR TRAILER (A51222)
CUSTOM ALUMINUM...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2018 John Deere 460E Articulated Dump Truck (A52128)
2018 John Deere...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
