Low oil pressure sensor + diesel generator
   / Low oil pressure sensor + diesel generator #1
dlabrie
Gold Member
Campton, NH
Kubota B2910
I have a 5 year old Aurora portable diesel generator, # AGI16500DE. It has an 11 HP, 186F type, single cylinder, 3600 rpm, diesel engine.
The oil pressure sensor is leaking. I tried tightening it but that didn't work. Can anyone tell me if this sensor is an off-the-shelf item? I found this Amazon.com: Standard Motor Products MC1804 Oil Pressure Gauge Switch: Automotive on Amazon, but have no idea if it would work.
Here is a picture of the leaking sensor.
Thanks.
   / Low oil pressure sensor + diesel generator #2
Have you tried removing it and putting teflon tape on it?
DEWFPO
DEWFPO
No, It's not leaking from the threads. It is coming from the seal between the black part and the ring.
The manual says it is a 15PSI sensor, but I can't find any info on PSI ratings on Amazon.
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
3in Poly Pipe (A49461)
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2007 WABASH 53FT DRY VAN TRAILER (A51222)
2007 WABASH 53FT...
GENERATOR HOUSE POEWERED BY TWIN 12.7 DETROITS (A50854)
GENERATOR HOUSE...
2016 Ford F150 Ext. Cab Pickup Truck (A50323)
2016 Ford F150...
