Low oil pressure sensor + diesel generator
   / Low oil pressure sensor + diesel generator #1
dlabrie
Gold Member
Campton, NH
Kubota B2910
I have a 5 year old Aurora portable diesel generator, # AGI16500DE. It has an 11 HP, 186F type, single cylinder, 3600 rpm, diesel engine.
The oil pressure sensor is leaking. I tried tightening it but that didn't work. Can anyone tell me if this sensor is an off-the-shelf item? I found this Amazon.com: Standard Motor Products MC1804 Oil Pressure Gauge Switch: Automotive on Amazon, but have no idea if it would work.
Here is a picture of the leaking sensor.
Thanks.
   / Low oil pressure sensor + diesel generator #2
Have you tried removing it and putting teflon tape on it?
DEWFPO
DEWFPO
No, It's not leaking from the threads. It is coming from the seal between the black part and the ring.
The manual says it is a 15PSI sensor, but I can't find any info on PSI ratings on Amazon.
2004 Capacity Yard Spotter Truck - Cummins Diesel, Allison Auto, Low Hours (A51039)
2004 Capacity Yard...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2018 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2018 PETERBILT 579...
2006 PETERBILT 379 DUMP TRUCK (A51222)
2006 PETERBILT 379...
