Low oil pressure sensor + diesel generator
   / Low oil pressure sensor + diesel generator #1
dlabrie
Campton, NH
Kubota B2910
I have a 5 year old Aurora portable diesel generator, # AGI16500DE. It has an 11 HP, 186F type, single cylinder, 3600 rpm, diesel engine.
The oil pressure sensor is leaking. I tried tightening it but that didn't work. Can anyone tell me if this sensor is an off-the-shelf item? I found this Amazon.com: Standard Motor Products MC1804 Oil Pressure Gauge Switch: Automotive on Amazon, but have no idea if it would work.
Here is a picture of the leaking sensor.
Thanks.
   / Low oil pressure sensor + diesel generator #2
Have you tried removing it and putting teflon tape on it?
DEWFPO
DEWFPO
No, It's not leaking from the threads. It is coming from the seal between the black part and the ring.
The manual says it is a 15PSI sensor, but I can't find any info on PSI ratings on Amazon.
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
Komatsu D39PX-24 Crawler Tractor Dozer (A49346)
Komatsu D39PX-24...
AUCTION STARTS HERE @ 9AM (A51242)
AUCTION STARTS...
Harper SB1300 Straw Blower with Hose (A51039)
Harper SB1300...
2016 INTERNATIONAL 4300 24FT BOX TRUCK (A51219)
2016 INTERNATIONAL...
2009 JACK COUNTY 130 BBL VACUUM  TRAILER (A50854)
2009 JACK COUNTY...
