Low hour diesel engine failure.
/ Low hour diesel engine failure. #1
ORCM
OC, OREGON
JD 2038R
Does anyone know what would cause a low hour motor (330hrs) to have stuck rings, and leaky pitted valves? The tractor was running fine, and then it just wouldn't start. The dealer is telling me that it's due to fuel contamination, but it seems like it would run bad when that happens
/ Low hour diesel engine failure. #2
Does anyone know what would cause a low hour motor (330hrs) to have stuck rings, and leaky pitted valves? The tractor was running fine, and then it just wouldn't start. The dealer is telling me that it's due to fuel contamination, but it seems like it would run bad when that happens[/QsUOTE]
Stuck rings and burned valves I would look into just how much gas has been put in tank.
ken
/ Low hour diesel engine failure. #3
ken
Yep, that would be my guess, especially with the burned valves.
/ Low hour diesel engine failure. #4
A diesel engine has a certain amount of delay from the time injection starts till the fuel ignites, when you add gasoline the mixture ignites early and it gives you increased cylinder temperature and white smoke. There is a dramatic loss of power. Carbon, sticking the rings, could be from lack of air, or retarded timing. both would give reduced power.
The pitting of the valves, with the hours of the engine that is a quality issue. There is absolutely no reason for a valve to pit at that low of hours.
There is no way that I put gas in it. I pull from a 50gal transfer tank, and the fuel had die in it.
The tractor was running fine, till I shut it off. It wouldn't start.
/ Low hour diesel engine failure. #6
Places where gasoline can be erroneously introduced into diesel: racks, tanker, service station, and consumer's tank.
/ Low hour diesel engine failure. #7
I suggest you drain some fuel out of the tank and get it analyzed.
It's possible the fuel was contaminated when you bought it...that's going to be very difficult to prove though.
/ Low hour diesel engine failure. #8
When was your transfer tank last filled? Possible they started a gas fill and OOPS! then changed hoses and filled with diesel. I am not a chemist, so I don't know if gas and diesel would mix or which would go to the bottom of the tank if they do not mix. I would have this tank sampled and tested for gas contamination. I do not see the dealer having anything to gain (you are not in warranty correct?) by lying about the cause or spiking your tractor's tank with gas.
/ Low hour diesel engine failure. #9
Putting around idling, light loads, low coolant temps and winter starting without using a block heater will all crud up an engine. Using a low ash post 2007 highway truck oil or a high ash engine oil?
Told the dealer that I wanted to have the cylinder goo analyze, to see what residue compounds are found. I'm also going to have the fuel in my transfer tank analyzed by the local Cat dealer.
I don't do this. Not sure on the oil, but the bottom end of the motor looked good.
/ Low hour diesel engine failure. #12
I am wondering if you could have a failed air filter, filter housing, or intake hose. If an engine eats enough dirt, it will wipe out the rings and wear the valves prematurely. Were the intake valves in worse condition than the exhaust? Was there any sign of dust in the intake? Also, did the engine ever overheat?
/ Low hour diesel engine failure. #13
Are both valves damaged, only the intakes, or exhaust?
ken
that would be detonation and I would think that only the intakes would be burnt.
Retarded timing would make it burn only the exhaust valves. I know of no reason it would burn BOTH valves other than maybe dusting the engine.
might also be a good idea to have the oil analyzed, dusting will show up as High silicone in the oil.
I wonder this too. However, when I was trouble shooting it myself I checked the air filters. The inter filter looked new, and the intake pipe passed the filter was clean. All the hose clamps were tight from the filter housing to the block. If it was leaking, wasn't leaking very much.
I fill 50gal transfer tank at a local fuel distributor, and I watch them when they fill the tank. They use the same pump that they fill their trucks, and I don't even think they have gas there.
I took my sample out of my transfer tank tonight, and I will mail it tomorrow. Hopefully I will get the results back within a week.
/ Low hour diesel engine failure. #17
Ok, I was thinking you had fuel delivered, maybe filled when you were not around. So that can be ruled out.
/ Low hour diesel engine failure. #18
An engine taking on a load of dust does not affect the valves, it does not stick the rings it works like lapping compound and wears the rings out it will also wear the rod bearings
The bottom end/ bearings looked good, so I must be using good oil. The cylinder walls looked good, and still had some hatching. The pistons had this weird goo on the top, and upper sides. I have never seen rings do this before, in fact you could hardly tell were the split was in the ring it was stuck so tight.
I'm thinking that they may be some what right, It wasn't gas, but bad diesel.
Well got the call, $3K to fix my tractor. Guess I won't be upgrading any time soon.
