Low boy axle question
/ Low boy axle question #1
EdinOR
Oregon
69 Massey 175, 51 JD B, 48 JD H, 48ish York Turn O Bout
Hello,
I just picked up a small flatbed that a guy built decades ago. He used mobile home axles on it which seem to have a 5 x 5.5 pattern which also incorporates a 7.00 x 14.5 tire size. What I'm wanting to do is to put automotive or trailer rims on it so I can put wider tires on it. My question is, will any 5 x 5.5 fit? I know that I'll have to do some measuring to get the correct offset.
Thanks.
/ Low boy axle question #3
A wheel with a 5 on 5.5” pattern is a common Scouts, Ford and Jeep used it to name a few, but there are likely many more.
/ Low boy axle question #4
Some like the Scouts had a larger center hole vs say the 70s and 80s F150 due to the Scout using and external hub vs the F150s stronger internal hub.
/ Low boy axle question #5
I'm pretty sure my '14 Ram 1500 was a 5 on 5-1/2.
A wheel with positive offset will allow using spacers to get zero offset I'm guessing the current wheels have. Then again, I wouldn't spend much money on mobile home axles.
/ Low boy axle question #6
Suzuki samurai used that bolt pattern but used a larger center hole than dodge.
/ Low boy axle question #7
Hello,
Thanks.
check hole size
/ Low boy axle question #8
Change those axels before you get too far in the weeds. You'll end up hating them and change them eventually anyway.
2018 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A69167)
2018 FREIGHTLINER...
2020 Deere 670GP (A64126)
2020 Deere 670GP...
CAT 330BL Bucket (A68134)
CAT 330BL Bucket...
2009 POLAR TANK . (A67714)
2009 POLAR TANK ...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
