Low boy axle question
/ Low boy axle question #1
EdinOR
Oregon
69 Massey 175, 51 JD B, 48 JD H, 48ish York Turn O Bout
Hello,
I just picked up a small flatbed that a guy built decades ago. He used mobile home axles on it which seem to have a 5 x 5.5 pattern which also incorporates a 7.00 x 14.5 tire size. What I'm wanting to do is to put automotive or trailer rims on it so I can put wider tires on it. My question is, will any 5 x 5.5 fit? I know that I'll have to do some measuring to get the correct offset.
Thanks.
/ Low boy axle question #3
A wheel with a 5 on 5.5” pattern is a common Scouts, Ford and Jeep used it to name a few, but there are likely many more.
/ Low boy axle question #4
Some like the Scouts had a larger center hole vs say the 70s and 80s F150 due to the Scout using and external hub vs the F150s stronger internal hub.
/ Low boy axle question #5
I'm pretty sure my '14 Ram 1500 was a 5 on 5-1/2.
A wheel with positive offset will allow using spacers to get zero offset I'm guessing the current wheels have. Then again, I wouldn't spend much money on mobile home axles.
/ Low boy axle question #6
Suzuki samurai used that bolt pattern but used a larger center hole than dodge.
/ Low boy axle question #7
Hello,
Thanks.
check hole size
/ Low boy axle question #8
Change those axels before you get too far in the weeds. You'll end up hating them and change them eventually anyway.
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
John Deere 1025R (A62177)
John Deere 1025R...
Peruzzo Canguro 1600 Collection Flail Mower
Peruzzo Canguro...
Hobart Champion 16 AC/DC Engine-driven Welder and generator (A63689)
Hobart Champion 16...
2018 Jayco JayFlight 264BH (A62613)
2018 Jayco...
FIFTH WHEEL ATTACHMENT PLATE (A65643)
FIFTH WHEEL...
