Oil & Fuel Lost dipstick plug
/ Lost dipstick plug #1
E/S
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
I developed a oil leak on my M8540 today.
After a lot of cleaning and searching I discovered I lost the plug out of the block for the right side dipstick option.
any idea of size or options to plug this hole with out waiting on special order parts ?
Thanks
E/S
/ Lost dipstick plug #2
E/S - - a picture or two would sure help a lot.
I got a couple of pictures just now, one is the area & the other is a close up shot of the hole with duct tape over it. Sorry for the tape, it decided to rain. KIMG0310.jpgKIMG0312.jpg
/ Lost dipstick plug #4
Go to the local hardware store or such, like Menards or Lowe’s even, Get a expandable rubber plug or well nut. Use a drill bit or such to get a rough hole size measurement to give you a idea of the plug size.IMG_0336.JPGIMG_0337.JPGIMG_0338.JPG
/ Lost dipstick plug #6
A tight fitting well nut would make a decent permanent repair, IMO.
I agree with the previous writer that this would solve the problem but then the other problem is "how much oil do you have in the engine?"
If it were me I would order a replacement dipstick right away. You don't if you lost oil or not?
/ Lost dipstick plug #7
To my understanding, I don't think he lost the dipstick. The plugged hole was for an alternate location of the dipstick, probably for a different tractor model.
/ Lost dipstick plug #8
best news for the op is that he located the problem in good time & posted @ the right place for solution as noted above
wonder how that item got lost? hope not blow by
good work
Thanks for all the input.
I didn't lose the dipstick, this is an alternate location.
While I like the well nut idea, the hole is approximately 1/2 in. At that size and location I'm worried about the shaft on the well nut breaking and dropping into the oil.
I don't know how it got away, I do know there is normal crankcase presser and the engine has 1200 hrs. on it.
I have decided to insert a snug fitting bolt into the hole and JB Weld it in. I will first rough up the hole, then clean it. I think this is the best way to make a permanent fix without tapping the hole.
Any thoughts on this ?
E/S
/ Lost dipstick plug #10
I wouldn't worry about the well nut coming apart, but your fix sounds fine to me.
Doug in SW IA
/ Lost dipstick plug #11
They make small “freeze plugs” you could use one of them.
/ Lost dipstick plug #12
I like country bumpkins idea of an expandable rubber plug or well nut. In the RARE instance - they will allow easy removal.
BTW - have you contacted your local dealer to see what originally capped that hole?? Maybe get a replacement from the dealer.
I haven't talked to my dealer, but from past experience they won't know any thing more than a part #.
I did look at some other Kubotas in the neighbor hood and they were plastic.
E/S
2022 BIGHORN EXPLORER 400 EFI UTV (A62130)
2022 BIGHORN...
CRATE OF DOOR LOCKS (A62131)
CRATE OF DOOR...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2014 Freightliner M2 106 Bucket Truck, VIN # 1FVACXDT2EHFU7070 (A61165)
2014 Freightliner...
UNUSED RAYTREE REDM32 - 32" HYD EXCAVATOR MULCHER (A62131)
UNUSED RAYTREE...
2021 Salford 550-30 Cultivator (A63116)
2021 Salford...
