Oil & Fuel Lost dipstick plug
/ Lost dipstick plug #1
E/S
Reno, NV
Kubota M8540HDC12-1 4x4 w/ Cab
I developed a oil leak on my M8540 today.
After a lot of cleaning and searching I discovered I lost the plug out of the block for the right side dipstick option.
any idea of size or options to plug this hole with out waiting on special order parts ?
Thanks
E/S
/ Lost dipstick plug #2
E/S - - a picture or two would sure help a lot.
I got a couple of pictures just now, one is the area & the other is a close up shot of the hole with duct tape over it. Sorry for the tape, it decided to rain. KIMG0310.jpgKIMG0312.jpg
/ Lost dipstick plug #4
Go to the local hardware store or such, like Menards or Lowe’s even, Get a expandable rubber plug or well nut. Use a drill bit or such to get a rough hole size measurement to give you a idea of the plug size.IMG_0336.JPGIMG_0337.JPGIMG_0338.JPG
/ Lost dipstick plug #6
A tight fitting well nut would make a decent permanent repair, IMO.
I agree with the previous writer that this would solve the problem but then the other problem is "how much oil do you have in the engine?"
If it were me I would order a replacement dipstick right away. You don't if you lost oil or not?
/ Lost dipstick plug #7
To my understanding, I don't think he lost the dipstick. The plugged hole was for an alternate location of the dipstick, probably for a different tractor model.
/ Lost dipstick plug #8
best news for the op is that he located the problem in good time & posted @ the right place for solution as noted above
wonder how that item got lost? hope not blow by
good work
Thanks for all the input.
I didn't lose the dipstick, this is an alternate location.
While I like the well nut idea, the hole is approximately 1/2 in. At that size and location I'm worried about the shaft on the well nut breaking and dropping into the oil.
I don't know how it got away, I do know there is normal crankcase presser and the engine has 1200 hrs. on it.
I have decided to insert a snug fitting bolt into the hole and JB Weld it in. I will first rough up the hole, then clean it. I think this is the best way to make a permanent fix without tapping the hole.
Any thoughts on this ?
E/S
/ Lost dipstick plug #10
I wouldn't worry about the well nut coming apart, but your fix sounds fine to me.
Doug in SW IA
/ Lost dipstick plug #11
They make small “freeze plugs” you could use one of them.
/ Lost dipstick plug #12
I like country bumpkins idea of an expandable rubber plug or well nut. In the RARE instance - they will allow easy removal.
BTW - have you contacted your local dealer to see what originally capped that hole?? Maybe get a replacement from the dealer.
I haven't talked to my dealer, but from past experience they won't know any thing more than a part #.
I did look at some other Kubotas in the neighbor hood and they were plastic.
E/S
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
SET OF (9) PUMP BOXES (A63569)
SET OF (9) PUMP...
2016 John Deere XUV855D (A62183)
2016 John Deere...
Swict 66" Bucket (A62183)
Swict 66" Bucket...
2024 Schulte 5026 Batwing Rotary Cutter (A63118)
2024 Schulte 5026...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
