losing power
/ losing power #1
dboose
Winston-Salem NC
2810 HST Mahindra
mahindra 2810 hst a lot of metal shavings in filter when hydraulic fluid was changed. after I changed fluid I blew a seal in the axle housing. repaired that. now the bucket will barely lift,and while pulling there is little power.can some one help. Iam about ready to shoot my tractor.
/ losing power #2
Has it been running long enough to get a lot of the air out of the system?
When I hear “blew a seal” I think over pressure. Was this an over pressure (not likely/possible in the axle) or was this simply a failed axle seal? Or maybe something else completely?
/ losing power
it was a failed seal, The metal shavings where brass looking.there is also a knocking noise
/ losing power #4
Should maybe pull screen out of trans and clean that.
2019 Takeuchi TL8 Track Loader with 72in Tooth Bucket (A63689)
2019 Takeuchi TL8...
2015 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2015 INTERNATIONAL...
2020 PETERBILT 367 (A65643)
2020 PETERBILT 367...
New/Unused 16 Gallon Landhonor Vacuum Cleaner (A65583)
New/Unused 16...
New/Unused CFG Industrial H12R Mini Excavator (A65583)
New/Unused CFG...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
