losing power
/ losing power #1
unclebunk
Fairhope, Al
Kubota BX24
I have a bx24 with 430 hours. This weekend I was mowing and the engine began to lose power. It would drop 300 to 500 rpm and then back up to max rpm. It did this several times while mowing. I am up to date on my maintenance, but it almost felt like the fuel was being cut off. I haven't had a chance to check on anything yet. Was wondering if there was anything to look for other than fuel filters. Anybody had this happen to them?
/ losing power #3
momentary safety seat switch from bouncing?? other safety switch momentary activation, loose connection at fuel cutoff solenoid valve...low fuel in tank sloshing around.
/ losing power
It could be the fuel cutoff solenoid. I have had an issue in the past when I could not get the tractor to shut off. After I unhooked the battery, I wiggled the solenoid and haven't had any issues since. The tank was nearly full so I don't think it was that. Also don't think it was the seat switch. Good ideas to check! Thanks!
2014 Freightliner Bucket Truck (A61307)
2014 Freightliner...
2000 Sterling L9513 Winch Truck (A61307)
2000 Sterling...
2013 Freightliner M2 106 Altec TA45M 44ft. Insulated Bucket Truck (A60352)
2013 Freightliner...
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
