losing power
/ losing power #1
unclebunk
Fairhope, Al
Kubota BX24
I have a bx24 with 430 hours. This weekend I was mowing and the engine began to lose power. It would drop 300 to 500 rpm and then back up to max rpm. It did this several times while mowing. I am up to date on my maintenance, but it almost felt like the fuel was being cut off. I haven't had a chance to check on anything yet. Was wondering if there was anything to look for other than fuel filters. Anybody had this happen to them?
/ losing power #3
momentary safety seat switch from bouncing?? other safety switch momentary activation, loose connection at fuel cutoff solenoid valve...low fuel in tank sloshing around.
/ losing power
It could be the fuel cutoff solenoid. I have had an issue in the past when I could not get the tractor to shut off. After I unhooked the battery, I wiggled the solenoid and haven't had any issues since. The tank was nearly full so I don't think it was that. Also don't think it was the seat switch. Good ideas to check! Thanks!
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
2023 Kubota M7-174P (Premium) 4WD Tractor - 400 Hours (A63688)
2023 Kubota...
2007 KOMATSU PC35MR-2 TRACKED LOADER EXCAVATOR (A59914)
2007 KOMATSU...
2020 Bobcat MT85 (A62177)
2020 Bobcat MT85...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
