looking to buy
/ looking to buy #61
I'll just throw my 2 cents in. My 3110D has TS to the left & start to the RT. I also have clutch safety switch:)
/ looking to buy #62
just never heard of the thermostart being activated in the start position when the clutch is disengaged, (switch open).
Studying that schematic, it appears that the safety switch only interrupts power to the starter. So 'heat while cranking' continues in Start key position, regardless whether power is reaching the starter or not.
So this creates an opportunity for someone with the 3-position ignition switch: Wire the TS to Start. Hold Start position 10-20 seconds with clutch engaged (Heating the TS but not cranking). Still holding Start position, push in the clutch to begin cranking.
/ looking to buy #64
So you are saying TS is activated any time the switch is in the START position.. I find that hard to believe.
/ looking to buy #65
I have put a voltmeter on my 2002d and yes it is hot while key is in crank position. I haven't tried it without the clutch switch engaged but I will.
/ looking to buy #66
Sorry normde, it is not my intent to try proving your wrong I'm sure you know way more than I do when it comes to Yanmar tractor, :cool:
its I'm just trying to come up with a logical answer for both of us, I cannot argue the fact that my ignition switch might have been replaced in the past, only that I know it will only turn one way, ( to the right ) and that it will start faster if I let it sit on run for 10 seconds before attempting to start it,
here is something I found from Hoye tractor parts, this is to be an ignition switch diagram for my 1700
Interesting, my YM2000 switch that I got from Hoye about 8 years ago looks nothing like that. Both original and new switches are exactly like the YM240/195 schematic shows. Should be same for YM1700.
/ looking to buy #67
I'm back. Mine works exactly as California described. Don't push the clutch, turn the key to crank, and 12 volts goes to the thermostart.
/ looking to buy #68
Strange, apparently there is a new switch that might accomplish that, but I'm pretty sure mine does not. Unfortunately it will be 4 months before I can check it out. As I said, it doesn't show on the schematic.
/ looking to buy #69
Let me be sure I'm understanding this clearly, when you Winston and California are saying "start position" you are saying all the way as in cranking the engine over.... right? not in run position? as in the first click to the right that only powers up the sytem,.......... if this were the case than someone may have my switch wired in wrong, and am wondering if once I have started the engine and let go of the switch to the run position if the TS is still activated:confused: and if this were the case then seems to me something would burn out by now, that being both the switch and the TS-right! Hmmmmm:confused:
/ looking to buy #70
That is true. There are two positions on the key switch which transmit power to the TS igniter-- TS position and start position. :thumbsup:
Mike
/ looking to buy #71
Take a look at the schematic again. On the ignition switch, R2 goes to Thermostart. C goes to the starter.
And apparently there is an internal bridge between C and R1 while the key is at Start. So ... If you have the optional jumper wire (mine does) between R1 and R2, then you have 'heat while crank'.
Dang everybody must be rained in, to put such attention into this trivia. I'll get outside as soon as the fog burns off and it gets above 45 degrees. 'Freezing fog' is how NWS describes here at the moment. Yesterday after it cleared, I got out and backhoed out a dead tree from the orchard. For once, the radiator heat blown back felt good.
/ looking to buy #72
Yes, my point exactly. I don't see how it can work either way.
/ looking to buy #73
It works when the switch is in crank position, does not work with switch in on postion.
/ looking to buy #74
to everyone fallowing this thread about the ignition switch, I found the ignition switch on my 1700 to have polarity on both run and at start position to the Tstart, My test meter isn't working at the time so I dont know the exact voltage so I used a test light, and get a dim light to the Tstart when switch is in run, although as I hold it on the Tstart terminal and attempt to crank the tractor the light gets very bright, so yes as the other more knowledgeable folks here have said the Tstart should only be working in the start position of this particular kind of switch that only turns to the right, I stand corrected, and will need to look further into why it has polarity in the run position, My apologies if caused any confusion about this subject:cool:
/ looking to buy #75
You could drive the TS from a pushbutton switch on the lower edge of the instrument panel. That is what the parts manual shows as 'early'.
I think this is why there is a rubber plug on the lower part of the panel.
Kubota V3600-T-E2 Turbo Diesel Engine - 3.6L - 84 HP - Tier 2 - Irrigation Takeout (A63689)
Kubota V3600-T-E2...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
Preliminary Listing / Full Catalog Coming Soon! (A62180)
Preliminary...
CASE 610 Sprayer System 2000 Gallons (A63688)
CASE 610 Sprayer...
2021 Chevrolet Silverado 2500 HD Single Cab Royal Service Truck (A64194)
2021 Chevrolet...
2011 Freightliner M2 106 Medium Duty T/A Dump Truck (A61573)
2011 Freightliner...
