Looking for splitter designs for CUT
/ Looking for splitter designs for CUT #1
NickTaylor
Maypearl, Texas
1998 John Deere 770
Hello,
I have a JD770 with rear hydraulics installed. A friend has offered to help me build a hydraulic splitter for firewood. Anyone have a design (or even a photo) they can share? Needs to be smallish so I can lift it with my 3 pt.
Thanks!
/ Looking for splitter designs for CUT #3
You need to look carefully at your hydraulic specs. I'm not sure how much gpm you can actually get through the rear hydraulic on a 770 but I'd guess it's pretty limited. I think you should stick with a 3 inch cylinder which will probably limit you to not much over 10 tons. Contrary to common wisdom, you can split a lot of wood with a splitter that size.
I've got a PowerHorse 13 ton on my 2320 and like it. However, if it wasn't a two way splitter, it would be a little slow. Take a look at that design. A two way would be a more complicated build, but with a small tractor, I think it's the best way to go.
/ Looking for splitter designs for CUT #4
I run a PTO splitter on my MT180D (about 20 hp).
Made it as 3 PT on an 6 x 8 H beam with a 5" old bulldozer cylinder.
I push logs into the wedge which is solid to the H beam end.
Slowish but fast enough for my liking. Sure beats a maul!
It can actually cut a 4" maple to length (cross grain) but U can see the H beam twist a bit and it cuts with a loud bang, but is a cool way to test my welding ability. LOL
/ Looking for splitter designs for CUT #5
Look at the Wallenstein 3PT splitters for design hints. Nice compact units and affordable. Might not be worth messing with building one.
/ Looking for splitter designs for CUT #6
MetKit Corp - Home Page
Select New Products
Lets Split Wood!
Spending $1000 or more on a splitter doesn稚 save you money on your heating bill. MetKit customers asked for a cost effective woodsplitter kit so we came up with the 800S. Turn your CADDigger Model 821 (or other CADDigger) into a powerful woodsplitter.
The 800S was developed as the lowest cost way MetKit could offer a woodsplitter kit. Simply weld the frame together, put the boom cylinder in from your 800 Series CADDigger, and you have a 7 ton, 20 inch woodsplitter! Split 10 to 12 inch diameter, 20 inch long wood with the 12 second cycle time.
Two Pin Installation
Easy On & Off
Simple Fabrication
Self Fixturing Design
Precision Cut Burnouts
All Steel Supplied including 2 pins
Instructions Included
800S Splitter kit ----- $265.00 delivered in the Continental US.
2001 GMC C7500 Fuel Truck (A62613)
2001 GMC C7500...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2000 Belshe dt-255 Trailer (A64194)
2000 Belshe dt-255...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
