Looking for more precise control of loader
/ Looking for more precise control of loader #1
felixedo
Bronze Member
Missouri Ozarks
New Holland TC35D / Deere 1026R / Bobcat CT2040
I have a Bobcat CT 2040 tractor with a loader. The issue I have is that there is a very small window on the joystick valve for slower, more controlled bucket lift / lower or tilt. It is especially bad when trying to gently use pallet forks. It is a very tense, 2 handed operation. I don’t want a flow control on the entire system, because sometimes I want the less precise, fast movement. Is there a valve with a more incremental window of control? Or another way to easily go slow when desired?
/ Looking for more precise control of loader #2
I suspect they don't use a loader valve with the metering notches on the spools to help with feathering of the controls.
For instance, when I built my loader, I found a used 3 spool valve for very very cheap ($40). It's a Bosch-Rexroth valve used on an old Case skidsteer, but it has all the features in needs, like those metering notches to allow feathering, which makes for a very pleasant operation.
Anyway, a low cost solution is to lower your engine RPMs. Less RPM = less flow = slower loader.
If you're already there, I suppose you could add some inline flow control valves on the lift and curl circuits that you would use to reduce the flow for delicate operations.
With these valves, you get two types: Bidirecional which controls the flow in both directions or Unidirectional that controls the flow in one way but lets full flow in the opposite way.
You could use two bidirectional flow control valves. One on the lift circuit and the other on the curl circuit. That way, you have only two knobs to adjust. Mount them between the quick connect and the hose on the loader valve.
Essentially, you adjust the flow control valves (they have markings so you can repeat easily) for delicate operations and open them all the way for everything else you don't care about going slow.
You'll need to figure out what fittings they use on the loader. Places like Discount Hydraulic Hose have plenty of fittings and Surplus Center have those flow control valves. Inline & Needle Valves | Flow Control Valves | Hydraulic Valves | Hydraulics | www.surpluscenter.com
/ Looking for more precise control of loader #3
lower rpms help for sure, maybe lube up the control stick base and cables? Any stiction isn't helping.
I find my loader very easy to control in one axis at a time. Blending lift and curl with smoothly and fast is hard to do, when I'm trying to show off how fast I can unload a hay wagon;).
I have heard from smaller Kioti users that my tractor loader is slow in comparison as its got bigger cylinders for more lift, but not much more hydraulic flow, but swapping bigger cylinders on yours wouldn't be worth it.
Maybe try the equivalent Kioti and see if they run a different control stick that might bolt right in?
