looking for advise
/ looking for advise #1
kerryf@alltel.net
Looking at buying a cub cadet 1527, pretty clean, had a roaring when blades are engaged?? 16hp kawaski with 449 hours?? any advise?
/ looking for advise #2
kerry...
It sounds as if you are concerned about the condition of the deck spindle bearings or belt idlers. If that is so it is worth removing the deck belt to allow hand turning each blade and idler.
If you are getting it at a great price... you can check this all out at your leisure when you service it the first time.
449 hours is nothing on a good deck... KennyV.
/ looking for advise #3
Spindle bearings likely just from first thought. Easy to replace. I think the HP is 17 on the Kawasaki. Kawasaki has been bullet-proof for me for years on both the 14 and 17HP models. .
/ looking for advise #4
My Cub sounds like a hovercraft when the blades are engaged. It has a lot of suction.
Bill
/ looking for advise #5
Got me a 1527(for the wife heh, heh), absolutly love it---cruise control, cup holder, etc. Yeah it sounds like a hovercraft when deck is engaged but with hydro trans and mulching deck life is good!!!!! Make sure your blades are aligned tip to tip 90 degrees to direction of travel or vibration will drive you nuts---450 hours is barely broke in.
Jerry
1996 International 4700 (A64127)
1996 International...
(APPROX. 450')LOT OF LATCH LOCK 6" IRRIGATION PIPE (A64278)
(APPROX. 450')LOT...
Wooden Glider Chair (A64557)
Wooden Glider...
2026 SDLANCH SDLC2020 High-End Carport (A64194)
2026 SDLANCH...
2021 PETERBILT 367 (A65643)
2021 PETERBILT 367...
(INOP) INTERNATIONAL 1066 TRACTOR (A64278)
(INOP)...
