Looking for a tractor
/ Looking for a tractor #1
mbrule
Masssachusetts
Yanmar/YM135
Hi Everyone,
Looking for some advice. I am looking for a tractor, somthing old (read cheap) with a loader. Looking for somthing I can use to move heavy things around my yard, and plow snow. Prefer somthing that runs and is usable, that I can work on and restore someday as need be.
Does anyone have advice on what tractors would be good candidates. I am looking to spend only a few thousand dollars. I live in Massachusetts, and would like to find somthing within a reasonable drive.
Thanks in advance for any help or advice!
Matt
/ Looking for a tractor #3
Hi...
Try Bargain News Online...
Ads mostly from CT NY MA...
Look in Yard Tools and Construction & Heavy Equipment categories...
A used compact utility tractor... or a smaller old farm tractor should be in your price range...
Dave...
/ Looking for a tractor #4
Try to get to some local auctions and see what is there. Watch the classifide ad's for something with a loader. Being unfamiliar (as your question implies) as you are with what you want, leaves a lot of 'help' we can provide almost impossible. Check with some local dealers, and get them in on a search for you.
Cheap, w/loader, fixable (restore), and 'usable-in-the-meantime' are in the 'twilight' zone, IMO. I do wish you luck.
/ Looking for a tractor #5
you said on ly a FEW thousand: how many? 3, 4 or 5?
there are inexpensive alternitives, and you're local situatiuon may be a bit harder as up there I'm not aware of how many FARMS there are left, much of that older inexpensive equipment may be gone, and replaced with newer stuff.
maybe check into the china forum, you can get a Homier, tractor with loader for the 6~7k range which will pick up and move lots of stuff. around here, people want as much for small 8/9Ns as you can but one of the china tractors NEW for! went to an auction this weekend, wanted 6500 for an old D modle 39 or 49? looked and ran OK to good, but still for that price I can buy NEW and the 9n was 2500 min bid, for a few hundred more you can get NEW diesel power from the Jinmas or Kamas.
also check and watch E-Bay, soemtimes stuff is there pretty cheap, but be warned lots of susposed scams going on. don't even think of bidding if you cant get there to pick up and or see prior to auction close.
Mark M
/ Looking for a tractor #6
Look in Uncle Henry's if you can find one. They sell them i ME, NH and VT. Maybe MA too. I am not sure. Good luck.
Thanks for all the help, you guys are right, those sources all have potential candidates.
I am looking for a small farm tractor, I already have a Yanmar subcompact with a loader. I want something bigger, and able to lift more (1000 - 1500 lbs at least). Looking to spend $3k or less. I am partial to old American iron (I restore cars for a hobby). The tractor cannot weigh more than 5500 lbs.
Does anyone have any opinions or recommendations on good / bad tractors to look at. I think a Ford n series would probably work well, IH models in that size, Deere (probably pricey). Just looking for experience, what tractors are out there, how parts availability is.....etc.
Thanks again
/ Looking for a tractor #9
Have you checked old industrial tractors with FELs? I know when I hear that I think of the old Fords. Not sure of model number, though.
/ Looking for a tractor #10
I am in Western Massachusetts and I have a 1942 Ford 9N with a loader in really good shape. I also have a John Deere 950 that I use all the time so the 9N mainly sits there. I bought it to refinish and use but with a new job, Graduate school and all the other things that I need to do, I just can;t find the time. It has brand new rear and front tires, new front tire rims, All new hydaulic hoses, new battery, new 6 volt alternator. I have manuals as well. I also have but have not installed two new rear fenders and a new front grill (all still in the boxes). Hood is in really good shape. Starts everytime, even when it sits for a month. I used it only three times this year, mainly just to start up and run. I have a plow attachment to replace the loader bucket for use in dirt, sand or snow. You can buy parts for this on EBAY or any one of the many 9N tractor sites on the net. Check it out. If you are interested email me at rmorency@charter.net and I can email you some pictures. Good luck with your search.
/ Looking for a tractor #11
I have a 9n, and will admit that it is a lousy loader tractor. Weak front end, high gearing, poor built in hydraulics. The original Dearborn loaders were intended for scooping feed and manure, not heavy dirt etc. And they are very slow, gravity down, trip bucket.
So for a cheap loader tractor, I would focus on IH/Farmall, or a newer Ford with power steering. I often see IH Utility tractors in good running shape with loader for $4,000 or so.
/ Looking for a tractor #12
Oliver 550 comes to mind as a good utility tractor with good design and worthy of repair and investment. Is a good workhorse when handling a FEL.
Thanks for the advice guys, I have been leaning towards an International. Don't really see a lot of olivers around here. While the Ford N series are about the size I want. More often than not thay are pricey.. collectors, I guess.
rmorency's Ford is a very nice looking tractor, if anyone is looking for a Ford. I need a fully hydraulic loader his has a trip bucket.
Matt
/ Looking for a tractor #14
The difference between a trip loader and a fully hyd loader is onl a d/a cylinder, and some spool valving.. assuming the pump capacity is there. ( belly pump, or stinger pump.. etc. )
Soundguy
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
2014 Freightliner Bucket Truck (A63689)
2014 Freightliner...
Atlas Copco Air Compressor & Air Dryer (A62613)
Atlas Copco Air...
2019 CATERPILLAR M316F MOBILE EXCAVATOR (A63276)
2019 CATERPILLAR...
