Looking for a name of an item
   / Looking for a name of an item #1
rasorbackq
Platinum Member
Springfield Nova Scotia Canada
Branson 4720
Have a locking device on my truck cap . All the wafers and releases, locks and springs are all sandwiched together by 3 will call them rivets . They are maybe 1/2" long round hollow and both ends are flared to hold the assembly together The holes in these things are 5/16 and are used to insert the bolts through them to attach to the cap.
There must be a name for these things . Was thinking I might be able to make some from a copper tube if I had the right diameter.
Help me out if you understand what I have described.
   / Looking for a name of an item #2
Picture would replace a thousand words....
What the problem is the latch is seized to the will call it a rivet again as the latch turns it turns the rivet.
The spring is not strong enough to flick open the latch due to too much friction.
   / Looking for a name of an item #5
I went to McMaster-Carr (if they don't have it...you don't need it!) and tried every combination of hollow, tubular, rivet, grommet and eyelet I could think of and couldn't find them.
If we could come up with the right name, I'd bet money McMaster has them.
   / Looking for a name of an item #6
POP RIVET, available in stainless steel and aluminum, and coated steel. Lowes, Home Depot, etc. Kits with the setting tool are common.
prs
   / Looking for a name of an item #7
I think you'd better off buying a new latch rather than trying to repair with those "pop rivet,eyelet," thingy's. If you could find them you'd need some way of crimping them.
   / Looking for a name of an item #8
Thinking of what I just posted I googled "crimpable eyelets" and came across something similar. Almost like a tarp grommet.
   / Looking for a name of an item #9
I would use a sleeve and a bolt, or a sleeve, spread the ends with a pointed punch and then smash them flat on an anvil.
Aaron Z
   / Looking for a name of an item #10
Good idea!
   / Looking for a name of an item #12
Looks like a piece of tubing with the ends flared. A tubing flaring tool might work. I do think buying a new lock is the way to go.
   / Looking for a name of an item #14
Go to Boltdepot.com and look at *** bolts and mating screws see if that will work.
   / Looking for a name of an item #15
No parts available for the cover. What I did was drilled out the hollow rivet Inserted a ss 5/16 tube inside . Flared one end before inserting and then enlarged the other end with a flared punch neck.
Good for another 15 years.
   / Looking for a name of an item #17
My money's on 16 years (at least). :thumbsup:Outstanding!
2008 Ford F-350 4x4 Ext. Cab Knapheide Service Truck (A59230)
2008 Ford F-350...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
CATERPILLAR TH255C TELESCOPIC FORKLIFT (A60429)
CATERPILLAR TH255C...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
2020 Toyota Tacoma Crew Cab Pickup Truck (A59230)
2020 Toyota Tacoma...
2006 CHEVROLET EXPRESS SERVICE VAN (A59904)
2006 CHEVROLET...
