Looking for a bulkhead fitting
/ Looking for a bulkhead fitting #1
Monster5601
Platinum Member
Oakland, MI
Kubota B3030 R4 Tires
First off, I have little idea what I'm talking about, I've done research and reading so I think I'm calling everything correctly but, if I were, then I should be able to locate the bulkhead fitting I need or a way to do what I what to do.
I am replacing both of my rear remote circuits from the Parker 9006 (push on pull off) couplers to a more traditional coupler/collar. What I have is a hydraulic hose attaching to an adapter that fits into the hydraulic coupler. The coupler side is a 1/2-14 NPT, the hose side is a 3/8-19 BSPP with an internal 55 degree flare (see picture). I would like to find this fitting in a design that could be mounted in a plate I can frabricate to replace the silly and hard to use push to connect and pull to disconnect system now on the tractor (see other picture).
If you know where I can find the fitting I'm looking for or perhaps another method I can use to achieve the same results, I would be very appreciative.
/ Looking for a bulkhead fitting #2
check on Surplus Centers web site they have several bulkhead fittings
Let me add, that I have searched all the sites Google has brought up without success. Either the part I need isn't made or I'm using the incorrect search criteria. This is the help that I am looking for.
/ Looking for a bulkhead fitting #4
View attachment 565083 View attachment 565084
Just curious, how on God's green earth did you come up with a British fitting? ****, we beat those people back in the Revolutionary War!
/ Looking for a bulkhead fitting #6
/ Looking for a bulkhead fitting #7
Or just weld a coupling onto your mounting plate, screw your fitting into one side, mount your quick connect on the other side
/ Looking for a bulkhead fitting #8
Just in case, here's a good article for identifying different types and sizes
Royal Brass and Hose Blog
here's a couple places to look
Hydraulic Adapters | HydraulicsDirect.com
Pressure Connections Corp - JIC BULKHEAD FITTINGS
/ Looking for a bulkhead fitting #9
Beat me to it, i was going to say the same thing.........Mike
I didn't, this is the rear remote kit straight from Kubota, they did it. From what I understand from reading, we are about the only country that doesn't use the British fittings.
This looks like the best solution since taking the adapter path I end up with a train of adapters that is too long to be workable.
Thanks, guys.
2013 FORD ESCAPE SUV (A66091)
2013 FORD ESCAPE...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
HEAVYEQUIPMENT OFFICE ITEMS (A68842)
HEAVYEQUIPMENT...
2016 Nissan Altima Sedan (A66738)
2016 Nissan Altima...
2017 Chevrolet Malibu Sedan (A66738)
2017 Chevrolet...
2017 JAYCO WHITE HAWK CAMPER (A67714)
2017 JAYCO WHITE...
