Looking for a bulkhead fitting
/ Looking for a bulkhead fitting #1
Monster5601
Oakland, MI
Kubota B3030 R4 Tires
First off, I have little idea what I'm talking about, I've done research and reading so I think I'm calling everything correctly but, if I were, then I should be able to locate the bulkhead fitting I need or a way to do what I what to do.
I am replacing both of my rear remote circuits from the Parker 9006 (push on pull off) couplers to a more traditional coupler/collar. What I have is a hydraulic hose attaching to an adapter that fits into the hydraulic coupler. The coupler side is a 1/2-14 NPT, the hose side is a 3/8-19 BSPP with an internal 55 degree flare (see picture). I would like to find this fitting in a design that could be mounted in a plate I can frabricate to replace the silly and hard to use push to connect and pull to disconnect system now on the tractor (see other picture).
If you know where I can find the fitting I'm looking for or perhaps another method I can use to achieve the same results, I would be very appreciative.
/ Looking for a bulkhead fitting #2
check on Surplus Centers web site they have several bulkhead fittings
Let me add, that I have searched all the sites Google has brought up without success. Either the part I need isn't made or I'm using the incorrect search criteria. This is the help that I am looking for.
/ Looking for a bulkhead fitting #4
View attachment 565083 View attachment 565084
Just curious, how on God's green earth did you come up with a British fitting? ****, we beat those people back in the Revolutionary War!
/ Looking for a bulkhead fitting #6
/ Looking for a bulkhead fitting #7
Or just weld a coupling onto your mounting plate, screw your fitting into one side, mount your quick connect on the other side
/ Looking for a bulkhead fitting #8
Just in case, here's a good article for identifying different types and sizes
Royal Brass and Hose Blog
here's a couple places to look
Hydraulic Adapters | HydraulicsDirect.com
Pressure Connections Corp - JIC BULKHEAD FITTINGS
/ Looking for a bulkhead fitting #9
Beat me to it, i was going to say the same thing.........Mike
I didn't, this is the rear remote kit straight from Kubota, they did it. From what I understand from reading, we are about the only country that doesn't use the British fittings.
This looks like the best solution since taking the adapter path I end up with a train of adapters that is too long to be workable.
Thanks, guys.
2008 Ford E-250 Cargo Van (A66736)
2008 Ford E-250...
2011 PREMIER PUMP AND POWER 3HC-DM16 TOWABLE DIESEL PUMP UNIT (A67714)
2011 PREMIER PUMP...
2001 Generac SG0060 75kVA Natural Gas Generator (A66734)
2001 Generac...
CAT R550/D11R Ripper Teeth (8) (A68134)
CAT R550/D11R...
2009 FORD E350 CARGO VAN (A66091)
2009 FORD E350...
2017 RANCO BELKY DUMP (A67714)
2017 RANCO BELKY...
