Long 445 3pt problem
   / Long 445 3pt problem
so the valve that adds fluid to the cylinder is in that front hydraulic head?
It seems my valve is just partially open to add fluid but not add enough pressure.
From what im gathering on information the Pilot valve is the valve im looking at that adds fluid?
   / Long 445 3pt problem #12
It responds when oil is needed in the cylinder when the position control lever is raised. The Romanian machining had a lot to be desired. Fiat did a far better job. In 2002, Long was still having trouble with these valve, and went to Fiat- Italy for a better one. Other thing, I forgot to mention is the draft control lever must be in the lower detent to work properly.
alright that sounds like it has to be my problem.
I will check it out again and check the seat to be sure it is not damaged or clogged,
Thanks,
edit:
So untill I have time to test can somebody confirm my theory here?
If the hydraulic pump is bad but not dead it will pump a little fluid through the system with enough pressure to slighly work the valves and lift. but since it is such little pressure it is not enough to hold any weight on the lift?
Im going to get a pressure gauge and try it. at 2400 rpm it should be around 2200psi?
Thank you,
   / Long 445 3pt problem #14
So long as the pump is not sucking air & has enough pressure to lift and lower the 3PL , then I would expect that the lift cylinder would be mostly free of air.
Assuming that, then even with a worn pump ( or engine stopped for that matter ), once raised, the lift still should hold considerable load.
If the 3PL collapses under those conditions, you'd be thinking that the lift seals or lift valve are leaking / open.
UTB piston seals can age badly I was told.
Re lift Valve : As I recall, 450 UTB series has a flaw in the draft mode select lever ( small round lever on the outside rear of the main lever quatrant ). This lever selects whether main lever works in draft or position mode. The flaw is that this lever must only be moved while the lift arms are raised. (There is a warning plaque on mudguard).
If u don't the mechanism gets out of wack permananently : ours faulted to an uncalibrated draft mode ie some lift like yours.
My first and only experience with this was many years ago, but involved removing the quadrant , springs ( one bent) , levers and reassembling in the right position. I didn't have a manual so was trial & error. Trivial job if you know how it should be. Should be Fiat manuals out there.
(BTW, That UTB came with our farm and goes well/ no trouble so we've kept and use regularly)
As I recall all the position/ top link draft control is all done in this external cam & link stuff & there is a control shaft going into the internal raise lower valve. You can get to and test operate that shaft without too much bother so as to bypass the draft+position mechanism.
*You would want to keep in a safe operator position to avoid crushing injury in case the hoist magically springs to life*
HTH's ( BTW, take it easy when tightening bolts on a UTB ! )
external linkage is all free basically,
I ordered a gauge and am going to test the pressure.
i think the pump might be bad,
Thanks
Well good but bad news,
got the gauge,
Pressure at the remote at idle is about 18-1900 at 2400rpm it is at 2500psi.
This has got me confused. I guess Im just going to have to take the whole assembly off and check it out.
I think there is a bad linkage somewhere. and it is opening just enough to flow a minute amount of fluid.
or a plugged line? I would think 2000+ psi would push any plugs out.
Im at a loss,
Thanks for the help so far,
Just read Andrews post again, I must not have picked that up about the draft control lever,
I will have to take that apart and look at it. That seems very likely, I have been able to get it to jolt a little bit by fiddleing with some of the different controls,
I will try this tomorrow,
Ok,
got it figured out,
The "valve" behind the three point lever was not moving or moving very little,
I took it apart moved it manually and it worked,
but it seems the assembly was not in the correct position in the first place and I don't know how it goes back together,
does anyone have a diagram on that assembly (the draft control and three point lever )
Thank you for all the help it has been very appreciate,
Kody
   / Long 445 3pt problem #18
Kody
Hope u have sorted by now. Could help if yr stuck. Unfortunately not possible to photo ours without pulling the quadrant off, but I can see in thru the gaps enough to describe if u ask specifics.
rgds
Andrew
Hello Andrew,
I ordered a manual so hopefully that will tell me what I need, If not I will come to you for specifics,
Thanks Guys,
Kody
Alright,
a little frustrated, ordered a $50 manual and it is of pretty poor quality. thats my first complaint, my second is that it don't even have what I need a picture of.
I can't figure the 3pt linkage out for the life of me, Either something is missing ( which I don't think is true ) or im just stupid. Ive spent hours trying it different ways.
I can work it manually by moving the "valve's lever" ( the one behind the quadrant ) and it works flawlessly that way. but as soon as I hook the linkage up it always binds, nothing looks bent. I think I understand how it works but I honestly can't figure it out.
Im very close to just building my own linkage. If it weren't for the draft control i prolly wouldn't have any problems right now.
if somebody could try to take pictures of theirs or make a quick sketch. something that give me a place to start from. Im just so frustrated with takeing it apart and puttin it back then it don't work.
Thanks fr the help so far,
Kody
2019 Takeuchi TS80V-2 Skid Steer, PIN# TKV80201102, Deutz Diesel Engine, Joystick Operating (A59076)
2019 Takeuchi...
2009 CHEVROLET SILVERADO 1500 (INOPERABLE) (A58214)
2009 CHEVROLET...
2014 Audi Q5 AWD SUV (A56859)
2014 Audi Q5 AWD...
2008 Isuzu NPR-HD Landscape Dump Truck (A56858)
2008 Isuzu NPR-HD...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
2006 GEA Westfalia Separator CA 501-00-32 Two-Phase Decanter Centrifuge (A56857)
2006 GEA Westfalia...
