Long 2360 FEL connection
/ Long 2360 FEL connection #1
avarageerod
NC
1993 Long 2360
I recently installed a front end loader on my Long 2360. I currently have it connected to the rear remotes and keep the handle tied back, which works fine, but do need my remotes for other implements. How can I connect my FEL to the tractor hydraulics without using the rear remotes? I have seen the pump that bolts onto the back and runs off the pto, but I would assume that you have to have a external reservoir for that to work. I know it can be done, but wanted to ask before I started tapping into hydraulic lines. Any help would be appreciated.
bumping up my old thread. I still haven't changed my connection points, but thought i'd ask again.
/ Long 2360 FEL connection #3
I know this is an old thread. Did you get your FEL connected?
/ Long 2360 FEL connection #5
Was going to help out if he still needs the help. My 2460 has the 1550C on it.
