Gregster613
- Joined
- Apr 19, 2009
- Messages
- 1,045
- Tractor
- 273 TYM. 2009 //Yardmachines 7 Speed Shift-on-the-goScotts L2048
I recently purchased a "new" Craftsman 27 Ton logsplitter. Have used 4 tanks of fuel so far (thus - about 4 hours on unit). The thing starts great, runs strong, and has split anything I've run through it so far.
However.....whenever I'm running it - it seems to constantly cough out Hyd fluid through the vent hole located on top of the check Hyd oil dipstick.
Every time I use it, it needs to be topped off with Hyd fluid. The manual gives me no troubleshoot guidance in this arena, and I'm pretty sure it shouldn't be doing this.
While I know Hyd fluid is much cheaper to replace than a blown Hyd pump - I just wonder if there are any other owners out there who have experienced this problem? If so, what was/is the fix? It's not overfull, and takes about 1/2 - - 3/4 of a quart to replace, after each hour long session of splitting. Plus -- it's just danged messey. Any help? Thanks, Greg
