Some hydraulics 101. your system is an open spool type, meaning that the pump is always moving oil from the pump-valve-tank-pump. When you move the valve to activate the cylinder, internal passages open and close to direct the flow to the pressure side of the cylinder and allow the opposite side to drain back to the tank. When the engineer designs the system he takes the flow rate of the pump and calculates the inside diameters of all the lines, suction and pressure, for acceptable pumping losses. Now a 1/4 inch inside diameter line costs less than a 3/8 inch line, however the pumping loss is greater which = heat. Add on that you are working the splitter and that increases the heat. You can do a few things to cool things off. Replace the lines with a larger ID line or add an oil cooler in the suction line. You never want the oil to be more than 180 deg; 130 150 is a good range.
BTW, one side of the pressure relief valve is 2,000 psi and the other is near 0, when the valve opens to limit the pressure all that energy has to go some where and it too shows up as heat.
