Log splitters
/ Log splitters #21
sharp101,
Some of those fittings look like water pipe fittings. Can you verify?
Big No No
/ Log splitters
I have went thru and took most of the pipe fittings out. Will post pictures of the painted and completed splitter soon. Thanks
/ Log splitters #24
It will be about 95 degrees here next week. Be cool.
/ Log splitters
Ron, I used the Honda engine, 22 gpm pump and 4 x 24 inch cylinder off my old log splitter to build this one. If everything was new I would have about $3000 in it minus labor.Sounds like a lot but I get a whole lot of satisfaction from it.
/ Log splitters #26
as a rule I try to use long stroke cylinders for lift tables to create smoother movement and reduce leverage on the lift table. shorter strokes can cause wood-a-paults
/ Log splitters
I am using restrictor fittings for the lift table and the 4 way wedge. The restrictors have aprox. a 5/64" hole in them. If you used the table and the wedge constantly this would heat up the hydraulic oil but just using when you need them, everything works out ok.
2015 Ford F-250 Knapheide Service Truck (A61573)
2015 Ford F-250...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
2020 International HX620 Quint Dump (A62613)
2020 International...
2015 John Deere 6130D (A64126)
2015 John Deere...
UNUSED WOLVERINE TDB-11-66W 66" BUCKET (A64281)
UNUSED WOLVERINE...
2022 EZ-GO ELITE...
