Log splitters
/ Log splitters #21
sharp101,
Some of those fittings look like water pipe fittings. Can you verify?
Big No No
/ Log splitters
I have went thru and took most of the pipe fittings out. Will post pictures of the painted and completed splitter soon. Thanks
/ Log splitters #24
It will be about 95 degrees here next week. Be cool.
/ Log splitters
Ron, I used the Honda engine, 22 gpm pump and 4 x 24 inch cylinder off my old log splitter to build this one. If everything was new I would have about $3000 in it minus labor.Sounds like a lot but I get a whole lot of satisfaction from it.
/ Log splitters #26
as a rule I try to use long stroke cylinders for lift tables to create smoother movement and reduce leverage on the lift table. shorter strokes can cause wood-a-paults
/ Log splitters
I am using restrictor fittings for the lift table and the 4 way wedge. The restrictors have aprox. a 5/64" hole in them. If you used the table and the wedge constantly this would heat up the hydraulic oil but just using when you need them, everything works out ok.
KBH Tender Trailer (A63688)
KBH Tender Trailer...
Pemberton Inc Komatsu Forks and Frame (A64194)
Pemberton Inc...
(4) HUSQVARNA CHAIN SAWS (A64276)
(4) HUSQVARNA...
SANY SY50U EXCAVATOR (A63276)
SANY SY50U...
New, Landhonor Skid Steer Pallet Forks  (A62679)
New, Landhonor...
More info coming soon (A61574)
More info coming...
