Log Splitter
/ Log Splitter #1
x703jko
Maryland
Kubota BX24TLB
Does anyone make a log splitter that can be powered by the rear hydraulics on the BX24?
/ Log Splitter #4
FWIW.........I think I saw a 3pt splitter at Tractor Supply yesterday.
Swmpbgy1
/ Log Splitter
Swmpbgy1
Interesting...I was at my local TSC and they told me they didn't carry a 3 point unit.
What brand of log splitter was it?
/ Log Splitter #6
Just called TSC and confirmed.......they are a Speeco log splitter for 3pt hitch. $645.62 and can take a log 26" in length.
Hope this helps.......
Swmpbgy.........
/ Log Splitter
Swmpbgy.........
Thanks. I'll check it out.
/ Log Splitter #8
Which TSC? I have seen them in the Mt. Airy store and also in Westminster...
/ Log Splitter
kennyd said:
Which TSC? I have seen then in the Mt. Airy story and also in Westminster...
The Westminster store...
/ Log Splitter #10
The Clarksburg, WV store has 3 in stock.......Not sure how far that is from you???
Swmpbgy1
/ Log Splitter
Swmpbgy1
I'll just order one from the local TSC if I decide to go this route.
/ Log Splitter #12
/ Log Splitter #13
Check out the specs on the splitter for the flow required. In the past there was a lot of discussion about splitters requiring more flow than a BX could deliver thus working the splitter at a crawl.
/ Log Splitter #14
Hey Jeff I purchased an American CLS splitter and decided to go with the stand alone splitter and not the 3 pt hitch model.
My Kubota dealer had both spitters there and the one thing I liked about the stand alone was the 13" tires which put the postion of the area where the logs goes higher than where it would be with the 3 pt hitch model.
I guess it all depends upon how much wood you are spittng, but I decided it was easier for me to pull the splitter out to the wood pile, leave it there and do the splitting. I can also move it around with the my 4 wheeler and do not have the tractor tied up.
Have had it for two years now and not a single problem I do about 12 cord a year so it is sitting more than it is used.
(I do have a 8 pound splitting maul for sale, cheap, if you decided not to buy a splitter) Haven't used it since I purchased the American. I don't care if I only have one or two pieces that need splitting I will use the splitter.
/ Log Splitter #15
Northern Tool has a 3 pt for $500 + frt. My brother and I both bought one and have had no problems. I run mine off of the rear hydraulic ports on my RTV900 or my JD 4710. The latter gives me faster cycle times but with the RTV I can split the wood and throw it straight into the dump bed.
This setup does not provide the quickest cycle times but you have plenty of power, there is essentially nothing to maintain, and the cycle times are acceptable to me. It's all good!:)
/ Log Splitter #16
I have a log splitter that ran off of the front loader hydraulics of a BX2230, I sold the 2230 and got a B7800 in April. I got the splitter from TSC in Follansbee WVa. It's a Huskee, and it works like a charm. Elm, oak, locust, and cherry, it eats 'em up. I does hook to the 3 pt. hitch. With the 2230, it cycled kinda slow due to the low pump output, it cycles a little quicker with the B7800. I think that a BX 24 is about the same size as a 2230, and the legs on my splitter drug on the ground sometimes if the surface was uneven with the 2230, but not so with the B7800. I had to have the 2 hoses made up to go from the splitter to the tractor which ran about 80.00, but well worth it.
Anyway, Huskee makes them, your tractor will run them, and it was money well spent. Good luck.
/ Log Splitter
Thanks for your thoughts. I'm on the fence right now. I know the American CLS model will work with the flow from the BX24, but it will be slow. On the other had, a towable, standalone splitter will be faster but more expensive.
I know I need to decide quickly since I have a lot of wood to split!
:eek:
/ Log Splitter
joewilshire said:
I just bought a 3ph log splitter on E-Bay. But I built a place to put a 6.5 hp motor and reservoir because I don't have a tractor. I got it this way cause it was cheaper than buying one built already. I also had to buy a pump but still the total cost was under $600.
Take a look at the one on e-bay. It may be just what you're looking for.
Joe
eBay: Log Splitter, 3 Point Hitch Attachment 16 Ton (item 280134615649 end time Jul-20-07 20:00:00 PDT)
Thanks for the ebay listing. Certainly a possibility. I'm a bit worried about the low flow rate from the BX24 - your idea of putting on my own hydraulics is tempting, but my concern is that this would be a major project and I have to get something soon as I have a lot of wood to split.
Decisions...decisions..
/ Log Splitter
What cycle time do you get and what's the flow rate and pressure from the RTV and the JD?
/ Log Splitter #20
My vote goes for a stand alone. We used to borrow a friend's stand alone for years. It was great because I parked our tractor perpendicular to the splitter with the FEL right there to my side. I split and stacked the pieces in the FEL immediately. One less handling. Very convenient. It was great. Had the need been there, I would have purchased a stand alone for this convenience.
The Gardener
2008 FORD F150 EXTENDED CAB PICKUP TRUCK (A66091)
2008 FORD F150...
275/70R19.5 Tire and Wheel (A68134)
275/70R19.5 Tire...
2004 Toyota Sienna Van (A66738)
2004 Toyota Sienna...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
ALLMAND NIGHT-LITE PRO II (A68842)
ALLMAND NIGHT-LITE...
1998 CHEVROLET C7500 (INOPERABLE) (A67714)
1998 CHEVROLET...
