Log splitter question
   / Log splitter question #1
ericm979
Super Member
Southern Oregon
Branson 3725H Deere 5105
I have an Oregon log splitter, 28 ton, one of those horizontal/vertical types. At full extension there's about 2" between the end of the wedge and the plate on the end of the beam that holds the round in place. Many times that's not enough to fully split the round. Sometimes I can pull it loose by hand but sometimes I have to turn the round and split it from the other side. It really kills my throughput. Some of the species I've split don't have this problem but most do. Bay is particularly terrible in this regard but live and tan oaks aren't great either.
Is there a reason why there's that much of a gap between the wedge and plate? Some safety thing I don't know about?
   / Log splitter question #2
Keeps full pressure from being exerted against teh wedge...at least that is the only thing I can think of.
To solve the problem of not fully splitting. I just back off the ram and stick a chunk of wood sideways between it and the chunk being split.
   / Log splitter question #3
I was told it is so the wedge will not cut your hand off.
wonder if that would be worse than the mangle hand one would have after the hand was stuck between the wood and the piston for the last 20 inches.
   / Log splitter question #4
I have a 31 ton MTD. That does happen to me, but it's very rare and I split everything - locust, gum, etc. Interesting to hear that it happens often to you.
   / Log splitter question #5
I would go crazy if the wedge wouldn't hit the backplate on my splitter. More often than not, I have to fully extend the cylinder in order to cut the "strings" when splitting eucalyptus so it will cut those things. Sometimes it happens with pine too, unless it's fully dry. At the least the type of pine we get here.
As others said, it's probably done just for safety reasons.
   / Log splitter question #6
Make some sort of spacer,, leave 1/4" of gap,,,
I think the 2" gap is to probably suit a 4 way splitting adapter.
If you add a spacer, it would be kinda like a 2 way splitting adapter,, :rolleyes:
:ROFLMAO:
Probably the best spacer would be a block of aluminum,,
if the wedge hit the aluminum, there would be less damage than hitting a steel spacer.
When I built my splitter, I designed in an adjustable gap, pull a pin, and get the gap you want,,
I can probably get a 10 or 12 inch gap if it were needed,,
   / Log splitter question #7
Mine is the same. It’s pretty rare mine doesn’t split it though.
   / Log splitter question #8
It seems to me that the space although not needed for a majority of the cuts, gives an opportunity for a longer chunk to be put in and split. 95% of mine split at that point.
   / Log splitter question #9
I am on my third andd all of them stop short of the wedge. Simple solution when the round doesn't split is to chuck a handy split crosswise behind it and run the ram forward again.
   / Log splitter question #10
i would simply add a piece of steel to the base plate, and a few tack welds. my splitting wedge ends 1/2" from steel base. been working great for 14 years.
   / Log splitter question #11
Mine came a tad less than an inch - wedge to hydraulic plate. Just back it off and add a crosswise split. Go at it again. My very large Ponderosa pines get "stringy" on the few base chunks.
Either that or let the chunks dry for a year prior to splitting.
   / Log splitter question #12
I believe it’s mostly due to getting the best bang for the homeowner’s buck by advertising the value with working length capacity, low cost for the manufacturer with cylinder size (add two inches to a cylinder and $ goes up), and the practical fact that most rounds are already sufficiently split before the cylinder makes the full extension.
I can't believe I didn't think of putting a split in cross ways. I'll try that. If it works like I think it will, I'll add making a spacer to my list of fabrication tasks.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56438)
2022 John Deere...
Hydraulic rail grinder (A56438)
Hydraulic rail...
Tandem Axle Rear Trailer Frame (A55851)
Tandem Axle Rear...
2012 Mini Cooper Coupe (A59231)
2012 Mini Cooper...
2018 CATERPILLAR 259D SKID STEER (A60429)
2018 CATERPILLAR...
