Log Splitter Pump question!
/ Log Splitter Pump question! #1
Mid Michigan
2003 New Holland TC40D
I am thinking about building a log splitter. I wanted to get about a 8 HP motor and match it up to a 16 gpm pump. Is there a difference or advantage to getting a two stage pump? I know of a "truck" PTO pump that is 16 gpm, but not a two stage. Would this be a better pump for a splitter? And could the 8 HP motor handle this pump? It should have better cycle times than a two stage pump, right? Thanks for your replies!
/ Log Splitter Pump question! #2
Yes, a two stage pump configured for a logsplitter with the correct pressure relief/cutover valve should give faster cycle times. Both pump bodies work in parallel for high volume/low pressure operation. As soon as a load is encountered such as when the ram contacts the log, a pressure sensing valve shifts the pump from parallel to series operation where both pumps are in line for high pressure low volume operation. As soon as the load pressure drops below the valve setpoint such as when the log finally pops/splits opr you retract the ram, then it shifts back to parallel/high speed ops.
I have never owned a logsplitter and do all my splitting by hand, but I have worked a few over the years. some were better than others, but the larger HP ones sure had an easier life. Depending on the type of wood and frequency of use, 8HP may work OK, but if used hard on hard splitting wood, you may be working the engine pretty hard which will shorten it's life. 10HP may be a bit more expensive, but if you maintain it properly, it will not be worked as hard and the likleyhood of you having to replace it due to overwork is less.
/ Log Splitter Pump question! #3
I have a single stage pump on my spliter and it runs slow. If I do it again I will use a 2 stage pump for speed. A 2 stage pump is 2 pumps in one. with no load the ram runs fast up to the log, than one stage quits so the engine has enough power to pump up the pressure to split the log. an 8 hp motor is a good size to use and a 2 stage pump sized for 8hp will give give the best cycle time.
Mopacman, Is your single stage pump 16 gpm? I thought if the first stage on a two stage pump is somewhere around 12gpm with 750 #s pressure, then the second stage kicks in which is about 2000 #s pressure but gpm goes down to 4 gallons about. Am I wrong to think a 16 gpm single stage wont work? Or just does it need more than the recommended 8HP engine? :confused:
/ Log Splitter Pump question! #5
What everybody said is right, but may not click in without some background. Approximate HP requirements will be GPM x PSI/1714. That would be about 25HP for 16GPM at 2500psi. The 8HP would not drive that pump to give a high enuf pressure for tough stuff unless you geared it down about 3 to 1. That would reduce the delivery rate to 5gpm tho, and you dont want that cuz it would be slow. The same effect as the geardown could be achieved by tripling cylinder area but would have the same slodown effect because more fluid would have to be pumped even tho at proportionally lower pressure.
Your 8HP will drive a 10GPM two stage pump tho, giving good speed on a 4" cylinder up until significant resistance is encountered, then slow advance thru the tough parts as the pump automatically reconfigures for hi pressure at a reduced delivery rate. This only happens on the tough stuff. Many logs split at the lower pressure, the pump not reaching the shift point and therefore staying in its high delivery mode.
larry
Spyderlk, Thanks for your answer! I was thinking that it would take more than a 8 hp engine to run this pump. I just wanted to make sure.;)
/ Log Splitter Pump question! #8
For reference, I have a homemade splitter with B/S 7 hp engine and a Barnes 13 gpm 2-stage pump. It's about the right size for the engine, about all the pump that 7 hp can handle, I'd say. Spends most of its time in high speed. For some reason, it pushes the 4" cylinder mighty slow even with no wood on the table, about 18 sec. out and 15 sec. in. I've tried lots of things to speed up the operation, because it's borrrrring. I guess as I get older it'll seem about right. I have a 36" cylinder but set up stops so I can adjust the return length to the length wood on the table.
Jim
/ Log Splitter Pump question! #9
Jim
Check your pump. Your cylinder should moveabout 5" per second at 13gpm. May be stuck on slow or doesnt completely shift to fast mode. Does the engine run easy as the ram moves toward the log?
larry
/ Log Splitter Pump question! #10
Yep, runs easy, and hunkers in for the work when it shifts into low. Given that it's slow out and back, doesn't seem like a valve problem (been like this since valves were new). Has full power in a difficult split, I'd say. Ran it earlier with an 11 gpm pump (13 was in hope for more speed) and it was slower but about the same power. I've about given up on this speed problem. By calculation, this thing ought to cycle in about 13 seconds for both directions.
I don't want to steal this guy's thread. Maybe I'll post this on its own, though I did a couple of times last winter and haven't made headway. I seem to be getting older fast these days, so maybe my splitter and I will reach an understanding.
Jim
/ Log Splitter Pump question! #11
Jim, Any foam in the reservoir? With what Iv heard, you must have a leak on the suction side. If your filter is on suck side be sure its ample for intended flow at the low differential pressure available. Check filter joints, o-rings, seals, and hoses for leaking fittings, pinholes in hoses, etc. Takes less for air to get in than oil to get out!
Wouldnt worry too much about the thread for a few cycles. Michigander is building a splitter. Outing splitter issues is probably a plus.
larry
Dont worry about stealing the thread. I have been learning from you guys. I welcome all the tips! These logsplitters can sometimes be hard to figure out.:(
/ Log Splitter Pump question! #13
OK, thanks. Last winter I removed the shutoff valve I had on the suction (1¼" wr hose) line, and again replaced the spin-on filter on the 1" return line. There's no foaming in the tank. Valves are open center Prince detent. I have a log lifter on this splitter, with a separate detent valve. Supply is through ram valve, return runs through ram valve, then lift valve, then single filter/return line.
Pressure line from pump to ram valve is ½" I think, is that too small? All oil goes through that line first...
pic attached, see if the notes came with it.
Thanks for any assistance.
Jim
/ Log Splitter Pump question! #14
Jim
The speed issue is pure volume. Probably not totally solveable with one lunger power. I posted in another thread about my 3pt setup with a PTO pump. Its really fast but I've 26HP to drive it and the pump is 21GPM no second stage. Full cycle time in and out on a 4" cylinder is under 10secs. And it doesn't slow down any while splitting. I've been told that the pump volumes aren't as high in actuall application as the rating. So If you've got a 13GPM pump your probably actually only doing 10 or 11 at best.
2018 MERLO TF30-9-11.5 TELESCOPIC FORKLIFT (A63276)
2018 MERLO...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2000 PETERBILT 379(INOPERABLE) (A67714)
2000 PETERBILT...
2007 Chevrolet Silverado 1500 Truck (A63116)
2007 Chevrolet...
2025 60 Gallon Poly Diesel Tank w/ 12v Pump, nose, Nozzle and Pump (A64557)
2025 60 Gallon...
2012 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A66736)
2012 Freightliner...
